Vocore2 Recovery Through Boot Command Line
Posted: Fri Mar 16, 2018 4:03 am
				Does anyone know how to recover from the following, it won't let me select option "4" like I usually do, seems like its selecting option "3' on its own.
Connecting to /dev/tty.usbserial, speed 115200
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is low
You chose 3
0
Image Name: MIPS OpenWrt Linux-3.18.45
Data Size: 1146069 Bytes = 1.1 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
No initrd
Starting kernel ...
[ 0.000000] Linux version 3.18.45 (pep@elbono-bigguy) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49404) ) #5 Sun Jan 29 05:20:22 CST 2017
[ 0.000000] Board has DDR2
[ 0.000000] Zone ranges:
[ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
[ 0.000000] Writing ErrCtl register=0003e87a
[ 0.000000] Readback ErrCtl register=0003e87a
[ 0.000000] Memory: 126336K/131072K available (2532K kernel code, 130K rwdata, 520K rodata, 136K init, 186K bss, 4736K reserved)
[ 0.000000] NR_IRQS:256
[ 0.000000] CPU Clock: 580MHz
[ 0.240000] rt2880-pinmux pinctrl: pin io20 already requested by pinctrl; cannot claim for 10000e00.uart2
[ 0.240000] rt2880-pinmux pinctrl: pin-20 (10000e00.uart2) status -22
[ 0.250000] rt2880-pinmux pinctrl: could not request pin 20 (io20) from group uart2 on device rt2880-pinmux
[ 0.260000] of_serial 10000e00.uart2: Error applying setting, reverse things back
[ 0.270000] console [ttyS0] disabled
[ 0.270000] 10000e00.uart2: ttyS0 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.280000] console [ttyS0] enabled
[ 0.290000] bootconsole [early0] disabled
[ 0.300000] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.310000] m25p80 spi32766.0: found w25q128, expected en25q64
[ 0.310000] m25p80 spi32766.0: w25q128 (16384 Kbytes)
[ 0.320000] m25p80 spi32766.0: using chunked io
[ 0.320000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.330000] Creating 4 MTD partitions on "spi32766.0":
[ 0.330000] 0x000000000000-0x000000030000 : "u-boot"
[ 0.340000] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.350000] 0x000000040000-0x000000050000 : "factory"
[ 0.350000] 0x000000050000-0x000001000000 : "firmware"
[ 0.420000] 2 uimage-fw partitions found on MTD device firmware
[ 0.430000] 0x000000050000-0x000000167d15 : "kernel"
[ 0.430000] 0x000000167d15-0x000001000000 : "rootfs"
[ 0.440000] mtd: device 5 (rootfs) set to be root filesystem
[ 0.440000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.450000] 0x000000910000-0x000001000000 : "rootfs_data"
[ 0.470000] ralink_soc_eth 10100000.ethernet: generated random MAC address 86:23:b9:87:5f:37
[ 0.480000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[ 0.480000] mt7621_wdt 10000120.watchdog: Initialized
[ 0.490000] TCP: cubic registered
[ 0.490000] NET: Registered protocol family 17
[ 0.500000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.510000] 8021q: 802.1Q VLAN Support v1.8
[ 0.520000] squashfs: SQUASHFS error: Filesystem uses "lzma" compression. This is not supported
[ 0.530000] jffs2: Flash size not aligned to erasesize, reducing to 14912KiB
[ 0.540000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0x7368 instead
[ 0.520000] s[ 0.550000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000004: 0x09bb instead
quashfs[ 0.53[ 0.560000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000008: 0x9ddd instead
0000] jffs2: F[ [ 0.570000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000010: 0x0037 instead
0.540000] jff[ 0.580000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000014: 0x0002 instead
s2: j[ 0.5200[ 0.590000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000018: 0x00c0 instead
00] s[ 0.quas[ 0.610000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000001c: 0x0004 instead
hfs[ 0.53[ [ 0.620000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000020: 0x0006 instead
0.0000] jffs2: [ 0.630000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000028: 0x004f instead
F[ [ 0. 0.5[ 0.640000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000030: 0x0047 instead
40000] jff[ 0[ 0.650000] jffs2: Further such events for this erase block will not be printed
.s2: j[ 0.5200[ 0.00] s[ 0.quas[ 0.hfs[ 0.53[ [ 0. 0.0000] j[ 0.660000] jffs2: Empty flash at 0x00000038 ends at 0x00000040
ffs2: [ 0.F[ [ 0. 0.5[ 0.40000] jff[ 0[ 0..s2: j[ 0.5200[ 0.00] s[ 0.quas[ 0.hfs[ 0.53[ [ 0. 0.0000] j[ 0ffs2: [ 0.F[ [ 0. 0.5[ 0.40000] jff[ 0[ 0..s2: j[ 0.5200[ 0.00] s[ 0.quas[ 0.hfs[ 0.53[ [ 0. 0.0000] j[ 0ffs2: [ 0.F[ [ 0. 0.5[ 0.40000] jff[ 0[ 0..s2: j[ 0.5200[ 0.00] s[ 0.quas[ 0.hfs[ 0.53[ [ 0. 0.0000] j[ 0ffs2: [ 0.F[ [ 0. 0.5[ 0.40000] jff[ 0[ 0..s2: j[ 0.5200[ 0.00] s[ 0.quas[ 0.hfs[ 0.53[ [ 0. 0.0000] j[ 0ffs2: [ 0.F[ [ 0. 0.5[ 0.40000] jff[ 0[ 0..s2: j[ 0.5200[ 0.00] s[ 0.quas[ 0.hfs[ 0.53[ [ 0. 0.0000] j[ 0ffs2: [ 0.F[ [ 0. 0.5[ 0.40000] jff[ 0[ 0..s2: j[ 0.5200[ 0.00] s[ 0.quas[ 0.hfs[ 0.53[ [ 0. 0.0000] j[ 0ffs2: [ 0.F[ [ 0. 0.5[ 0.40000] jff[ 0[ 0..s2: j[ 0.5200[ 0.00] s[ 0.quas[ 0.hfs[ 0.53[ [ 0. 0.0000] j[ 0ffs2: [ 0.F[ [ 0. 0.5[ 0.40000] jff[ 0[ [ 0.760000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00010000: 0x5d44 instead
0..s2: j[ 0.5[ 0.780000] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1
DRAM bus: 16 bit
GPIO 46 is low
You chose 3
0
No initrd
Starting kernel ...
