AP + STA mode - can't communicate between clients
Posted: Mon Sep 10, 2018 2:14 pm
by dimitry
VoCore 2 is running in AP + STA mode. Connect to it with 2 clients. Both get DHCP addresses. Both can access internet. Tried SSH'ing from one client to the other - no connection. Tried pinging - no cigar. What to do?
Re: AP + STA mode - can't communicate between clients
Posted: Wed Sep 12, 2018 2:14 pm
check firewall, allow forward mode
Posted: Wed Sep 12, 2018 3:06 pm
by dimitry
How can I tell if it's enabled? Here is my firewall config:
firewall.@defaults[0]=defaults
firewall.@defaults[0].syn_flood='1'
firewall.@defaults[0].input='ACCEPT'
firewall.@defaults[0].output='ACCEPT'
firewall.@defaults[0].forward='REJECT'
firewall.@zone[0]=zone
firewall.@zone[0].name='lan'
firewall.@zone[0].network='lan'
firewall.@zone[0].input='ACCEPT'
firewall.@zone[0].output='ACCEPT'
firewall.@zone[0].forward='ACCEPT'
firewall.@zone[1]=zone
firewall.@zone[1].name='wan'
firewall.@zone[1].network='wan' 'wan6' 'wwan'
firewall.@zone[1].output='ACCEPT'
firewall.@zone[1].masq='1'
firewall.@zone[1].mtu_fix='1'
firewall.@zone[1].input='ACCEPT'
firewall.@zone[1].forward='ACCEPT'
firewall.@forwarding[0]=forwarding
firewall.@forwarding[0].src='lan'
firewall.@forwarding[0].dest='wan'
firewall.@rule[0]=rule
firewall.@rule[0].name='Allow-DHCP-Renew'
firewall.@rule[0].src='wan'
firewall.@rule[0].proto='udp'
firewall.@rule[0].dest_port='68'
firewall.@rule[0].target='ACCEPT'
firewall.@rule[0].family='ipv4'
firewall.@rule[1]=rule
firewall.@rule[1].name='Allow-Ping'
firewall.@rule[1].src='wan'
firewall.@rule[1].proto='icmp'
firewall.@rule[1].icmp_type='echo-request'
firewall.@rule[1].family='ipv4'
firewall.@rule[1].target='ACCEPT'
firewall.@rule[2]=rule
firewall.@rule[2].name='Allow-IGMP'
firewall.@rule[2].src='wan'
firewall.@rule[2].proto='igmp'
firewall.@rule[2].family='ipv4'
firewall.@rule[2].target='ACCEPT'
firewall.@rule[3]=rule
firewall.@rule[3].name='Allow-DHCPv6'
firewall.@rule[3].src='wan'
firewall.@rule[3].proto='udp'
firewall.@rule[3].src_ip='fe80::/10'
firewall.@rule[3].src_port='547'
firewall.@rule[3].dest_ip='fe80::/10'
firewall.@rule[3].dest_port='546'
firewall.@rule[3].family='ipv6'
firewall.@rule[3].target='ACCEPT'
firewall.@rule[4]=rule
firewall.@rule[4].name='Allow-MLD'
firewall.@rule[4].src='wan'
firewall.@rule[4].proto='icmp'
firewall.@rule[4].src_ip='fe80::/10'
firewall.@rule[4].icmp_type='130/0' '131/0' '132/0' '143/0'
firewall.@rule[4].family='ipv6'
firewall.@rule[4].target='ACCEPT'
firewall.@rule[5]=rule
firewall.@rule[5].name='Allow-ICMPv6-Input'
firewall.@rule[5].src='wan'
firewall.@rule[5].proto='icmp'
firewall.@rule[5].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type' 'router-solicitation' 'neighbour-solicitation' 'router-advertisement' 'neighbour-advertisement'
firewall.@rule[5].limit='1000/sec'
firewall.@rule[5].family='ipv6'
firewall.@rule[5].target='ACCEPT'
firewall.@rule[6]=rule
firewall.@rule[6].name='Allow-ICMPv6-Forward'
firewall.@rule[6].src='wan'
firewall.@rule[6].dest='*'
firewall.@rule[6].proto='icmp'
firewall.@rule[6].icmp_type='echo-request' 'echo-reply' 'destination-unreachable' 'packet-too-big' 'time-exceeded' 'bad-header' 'unknown-header-type'
firewall.@rule[6].limit='1000/sec'
firewall.@rule[6].family='ipv6'
firewall.@rule[6].target='ACCEPT'
firewall.@include[0]=include
firewall.@include[0].path='/etc/firewall.user'
firewall.@rule[7]=rule
firewall.@rule[7].src='wan'
firewall.@rule[7].dest='lan'
firewall.@rule[7].proto='esp'
firewall.@rule[7].target='ACCEPT'
firewall.@rule[8]=rule
firewall.@rule[8].src='wan'
firewall.@rule[8].dest='lan'
firewall.@rule[8].dest_port='500'
firewall.@rule[8].proto='udp'
firewall.@rule[8].target='ACCEPT'
Posted: Wed Sep 12, 2018 3:22 pm
by dimitry
My wireless configuration is:
wireless.ap.device='radio0'
wireless.ap.mode='ap'
wireless.ap.network='lan'
wireless.ap.ifname='ra0'
wireless.ap.ssid='internal'
wireless.ap.key='password'
wireless.ap.encryption='psk'
Both clients connect to VoCore on the same 'internal' wifi. Both get DHCP in the same range 192.168.61.X. So, they should both be in the same 'lan' zone. No forwarding should be necessary if I understand it correctly.
Posted: Wed Sep 12, 2018 7:42 pm
by dimitry
Updated to firmware 20180723V.bin and it's still not working
Posted: Wed Sep 12, 2018 8:00 pm
by dimitry
Tried adding forwarding to the firewall:
lan -> lan
wan -> lan
(lan -> wan is already enabled)
Hairpinning is also enabled:
root@OpenWrt:~# cat /sys/devices/virtual/net/br-lan/lower_ra0/brport/hairpin_mode
1
root@OpenWrt:~# cat /sys/devices/virtual/net/br-lan/lower_ra0/brport/multicast_to_unicast
1
Posted: Fri Sep 14, 2018 12:13 am
by dimitry
Nobody else has this problem? Vonger, you there?
Posted: Mon Sep 17, 2018 9:44 pm
by dimitry
Hi Vonger, Could you please provide further directions? I don't know what to do at this point. Thank you.
Posted: Tue Sep 18, 2018 9:20 am
I have no idea now, this should be simple...
If all you device can access VoCore2, the only problem block them communicate each other is firewall.
Try to change every REJECT to ACCEPT
