Installed a Package Using (–force-depends), Then Got Stuck
Posted: Wed Dec 04, 2019 6:24 pm
Hello gents,
I'm using VoCore2 running OpenWrt, and I did install a package this way:
kmod install kmod-usb-net --force-depends
After that the rebooting never ends :blush:
Thanks in advance and here is the terminal output:
U-Boot 1.1.3 (Aug 21 2018 - 23:55:37)
Board: Ralink APSoC DRAM: 128 MB
relocate_code Pointer at: 87fb8000
Software System Reset Occurred
flash manufacture id: c8, device id 40 18
find flash: GD25Q128C
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
Date:Aug 21 2018 Time:23:55:37
##### The CPU freq = 575 MHZ ####
estimate memory size =128 Mbytes
RESET MT7628 PHY!!!!!!
Please choose the operation:
0: Load system code then write to Flash via Serial.
9: Load Boot Loader code then write to Flash via TFTP. 0
3: System Boot system code via Flash.
Image Name: MIPS OpenWrt Linux-4.14.131
Data Size: 1497367 Bytes = 1.4 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
No initrd
Starting kernel ...
[ 0.000000] Linux version 4.14.131 (user@user) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 r7808-ef686b7292)) #0 Thu Jun 27 12:18:52 2019
[ 0.000000] Board has DDR2
[ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
[ 0.000000] MIPS: machine is VoCore2
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] random: get_random_bytes called from start_kernel+0x90/0x478 with crng_init=0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS2,115200 console=tty0 fbcon=rotate:3 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=000339fe
[ 0.000000] Readback ErrCtl register=000339fe
[ 0.000000] Memory: 124956K/131072K available (3466K kernel code, 178K rwdata, 832K rodata, 188K init, 201K bss, 6116K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 256
[ 0.000000] intc: using register map from devicetree
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] timer_probe: no matching timers found
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
[ 0.000012] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[ 0.007541] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[ 0.073503] pid_max: default: 32768 minimum: 301
[ 0.078201] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.084551] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.096916] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.106408] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.112362] pinctrl core: initialized pinctrl subsystem
[ 0.117949] NET: Registered protocol family 16
[ 0.148566] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.154156] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.159757] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.169440] clocksource: Switched to clocksource MIPS
[ 0.175521] NET: Registered protocol family 2
[ 0.180702] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.187396] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.193580] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.199827] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.205430] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.211784] NET: Registered protocol family 1
[ 0.219333] Crashlog allocated RAM at address 0x3f00000
[ 0.226199] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.238335] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.243957] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.263651] io scheduler noop registered
[ 0.267385] io scheduler deadline registered (default)
[ 0.273283] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.280691] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.290051] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.299068] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.699620] console [ttyS2] enabled
[ 0.707259] cacheinfo: Failed to find cpu0 device node
[ 0.717706] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.730795] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.745952] m25p80 spi0.0: gd25q128 (16384 Kbytes)
[ 0.755784] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.768663] Creating 4 MTD partitions on "spi0.0":
[ 0.778381] 0x000000000000-0x000000030000 : "u-boot"
[ 0.789368] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.801071] 0x000000040000-0x000000050000 : "factory"
[ 0.812213] 0x000000050000-0x000001000000 : "firmware"
[ 0.894733] 2 uimage-fw partitions found on MTD device firmware
[ 0.906766] 0x000000050000-0x0000001bd957 : "kernel"
[ 0.917726] 0x0000001bd957-0x000001000000 : "rootfs"
[ 0.928668] mtd: device 5 (rootfs) set to be root filesystem
[ 0.941709] 1 squashfs-split partitions found on MTD device rootfs
[ 0.954298] 0x000000580000-0x000001000000 : "rootfs_data"
[ 0.966912] libphy: Fixed MDIO Bus: probed
[ 0.986635] rt3050-esw 10110000.esw: link changed 0x00
[ 0.998731] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[ 1.017321] NET: Registered protocol family 10
[ 1.030542] Segment Routing with IPv6
[ 1.038083] NET: Registered protocol family 17
[ 1.047201] 8021q: 802.1Q VLAN Support v1.8
[ 1.067402] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 1.082788] Freeing unused kernel memory: 188K
[ 1.091815] This architecture does not have kernel memory protection.
[ 2.238108] init: Console is alive
[ 2.245325] init: - watchdog -
[ 2.429449] random: fast init done
[ 4.074142] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 4.216538] usbcore: registered new interface driver usbfs
[ 4.227828] usbcore: registered new interface driver hub
[ 4.238721] usbcore: registered new device driver usb
[ 4.254772] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.269959] ehci-platform: EHCI generic platform driver
[ 4.290897] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 4.304486] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 4.315091] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 4.326772] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 4.342953] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 4.379456] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 4.393172] hub 1-0:1.0: USB hub found
[ 4.401215] hub 1-0:1.0: 1 port detected
[ 4.412713] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.427057] ohci-platform: OHCI generic platform driver
[ 4.438000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 4.451820] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 4.467981] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 4.554445] hub 2-0:1.0: USB hub found
[ 4.562490] hub 2-0:1.0: 1 port detected
[ 4.583537] MTK MSDC device init.
[ 4.649668] mtk-sd: MediaTek MT6575 MSDC Driver
[ 4.666162] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 4.691424] init: - preinit -
[ 5.967329] rt3050-esw 10110000.esw: link changed 0x00
[ 6.271330] random: procd: uninitialized urandom read (4 bytes read)
[ 9.690390] jffs2: notice: (383) jffs2_build_xattr_subsystem: complete building xattr subsystem, 29 of xdatum (2 unchecked, 27 orphan) and 44 of xref (27 dead, 0 orphan) found.
[ 9.725975] mount_root: switching to jffs2 overlay
[ 9.774347] overlayfs: upper fs does not support tmpfile.
[ 9.799307] urandom-seed: Seeding with /etc/urandom.seed
[ 10.004010] procd: - early -
[ 10.010043] procd: - watchdog -
[ 10.704359] procd: - watchdog -
[ 10.711069] procd: - ubus -
[ 10.859343] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.022659] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.036129] random: ubusd: uninitialized urandom read (4 bytes read)
[ 11.050135] procd: - init -
[ 11.452684] kmodloader: loading kernel modules from /etc/modules.d/*
[ 11.500745] CPU 0 Unable to handle kernel paging request at virtual address 0000000c, epc == 80070c68, ra == 80070a90
[ 11.522317] Oops[#1]:
[ 11.526915] CPU: 0 PID: 465 Comm: kmodloader Not tainted 4.14.131 #0
[ 11.539782] task: 87d0c000 task.stack: 87626000
[ 11.548946] $ 0 : 00000000 00000001 00000000 8761b268
[ 11.559530] $ 4 : 80450e98 00000000 8761b12c ffff8000
[ 11.570115] $ 8 : ffffc000 fffffffc 00000020 00000114
[ 11.580698] $12 : 00000001 00000000 00000004 65646f6d
[ 11.591280] $16 : 8761b120 87627ec0 00000000 8761b12c
[ 11.601863] $20 : 8761b168 80450000 fffffff8 80450000
[ 11.612447] $24 : 00000000 00000000
[ 11.623031] $28 : 87626000 87627dd8 00000000 80070a90
[ 11.633617] Hi : 0000000e
[ 11.639433] Lo : 00000000
[ 11.645279] epc : 80070c68 load_module+0x1ab4/0x1dc8
[ 11.655682] ra : 80070a90 load_module+0x18dc/0x1dc8
[ 11.666077] Status: 1100a403 KERNEL EXL IE
[ 11.674551] Cause : 00800008 (ExcCode 02)
[ 11.682657] BadVA : 0000000c
[ 11.688477] PrId : 00019655 (MIPS 24KEc)
[ 11.696582] Modules linked in: mii(+) sha256_generic sha1_generic jitterentropy_rng drbg md5 hmac echainiv des_generic deflate zlib_inflate zlib_deflate cbc authenc crypto_acompress mmc_block mtk_sd mmc_core leds_gpio ohci_platform ohci_hcd ehci_platform ehci_hcd gpio_button_hotplug usbcore nls_base usb_common aead cryptomgr crypto_null crypto_hash
[ 11.759204] Process kmodloader (pid: 465, threadinfo=87626000, task=87d0c000, tls=77fc8dc0)
[ 11.776112] Stack : 8745dc80 014002c2 00000000 00000000 8761b12c 00007fff 8761b120 8006e5c4
[ 11.793045] 803671f0 80450000 c01b68f4 ffffffff 8761b268 87457000 00402374 80440000
[ 11.809978] 803ecf58 803f0000 80450000 80450e80 fffcd000 014002c0 8761afa0 0000000a
[ 11.826910] 00000000 00000000 00000000 00000000 6e72656b 00006c65 77fbd000 77fbd000
[ 11.843840] 00000000 800be2f4 878ea5b8 00000101 00000002 00000134 014002c0 000007cf
[ 11.860772] ...
[ 11.860772] ...
[ 11.865714] Call Trace:
[ 11.870660] [<80070c68>] load_module+0x1ab4/0x1dc8
[ 11.880365] [<800710cc>] SyS_init_module+0x150/0x158
[ 11.890425] [<800134ec>] syscall_common+0x34/0x58
[ 11.899947] Code: 8fbf00d4 0c009331 00000000 <8ec20014> 02802825 0c04b4a4 8c440088 1440ff8c 00409025
[ 11.919710]
[ 11.919710]
[ 11.922762] ---[ end trace 78e7fa44f8babf35 ]---
[ 11.933946] Kernel panic - not syncing: Fatal exception
[ 11.945559] Rebooting in 1 seconds..
[05000C0C][05000C09]
DDR Calibration DQS reg = 0000888A
