Mass produced product using VoCore2
Posted: Sat Nov 26, 2022 4:31 pm
I was thinking to use the tiny VoCore2 1 inch square board in a product that will be mass produced, however I'm wondering how this board can be soldered to any PCB?
If the VoCore2 board is placed flat on a surface (like a PCB) the pins are floating in the air because of the components that are on the bottom, so how can a machine solder it to the PCB?
Is there some kind of PCB socket or board connector for it?
Has anybody ever run into this problem?
Thanks
Thanks
