I may mass produce a product using VoCore2. However I notice that the VoCore2 isnt flat, so therefore it cant make contact with the PCB easily because of chips on the bottom.
So how can I use it on a wave solder machine or something like that to solder it to many PCB?
Anybody knows a solution? Is there some kind of board connector that can be used with it?
Mass produce project based on VoCore2
- iosdev
Re: Mass produce project based on VoCore2
You will need to make a hole on the PCB.
Please read the tutorial: https://vocore.io/v2.html, there is a picture https://vocore.io/img/v2/v2.size.png
Users browsing this forum: No registered users and 84 guests
