It works, I just can't access it... I am using it as a wireless router now and it's doing a good job at getting my laptop connected (such a cool little router). HOWEVER I do have a couple of... questions.
First off, the IP it seems is not 192.168.61.1 like the non-dock version (no ping, http or ssh response at that address). But I DO get a ping response from 192.168.1.1, but no http or ssh response. How do I access this thing?
Second, I am using it out of the box on first boot.. do I need to perform some sort of update (firmware, software, uboot), or is it good to go?
My goal is to modify this to be a sort of internet filter and bandwidth limiter... with a web interface that will show all connected computers, their activity and so on.
Thanks in advance,
Endat
VoCore + Dock is setup differently...
- Endat
- Endat
Re: VoCore + Dock is setup differently...
Okay, so apparently it boots into 2 different modes depending on whether you have ethernet plugged in on boot... the 192.168.1.1 was my local router, which apparently disables any access to 192.168.61.1 unless (I guess) I figure out what IP my local router assigned it (which.. a reassignment doesnt seem logical).
If I boot without ethernet plugged in, I can access 192.168.61.1.. but then I can't plugin the ethernet and have net without rebooting it...
How can I access it while it has ethernet?
- Raymond Day
Set your computer to the same sub net. The 3RD number in the IP the 4TH number any thing but not 1 like the VoCore has. Do it 2 to 255 or so.
Then you can connect to it.
In it's settings can then change the IP. You could change it so it get's a IP with DHCP or keep it static to a IP you want.
I guess you can't change it on it's web page.
A easy way is install WinSCP and log in to it with that. Edit the /etc/config/network file to change the IP and reboot it and it will have the new IP you want.
With WinSCP use "File protocol" SCP not SFTP.
Users browsing this forum: No registered users and 16 guests
