Worked on soldering a RS232 on it.
Raymond Day
Mon Mar 23, 2015 4:39 pm
I used the small connectors to do this. I solder the 4 pin one to the RS232 and then I pulled the pins out from another connector and used a power wire off a bad PC fan it has a 3 pin connector on the end of the wire that plugs right in the USB to RS232.
So I just pushed the pins to the connector but that did not work good it don't do a good connection. I did get some RS232 Data but messed up a lot.
Unsolder the connector and when I went to solder the wires right in I pulled a trace off the RXD2. So is there a place right on the board were I can solder that?
Used wire wrap on it and them on the pins out of one of the connectors on the ends. So fits super good in the board holes.
VoCore RS232 cable.jpg (50.41 KiB) Viewed 84497 times
Re: Worked on soldering a RS232 on it.
Tue Mar 24, 2015 3:16 am
Looks good :)
Raymond Day
Tue Mar 24, 2015 11:59 am
Looked at PDF of the board. But I don't see were the RS232 would hook up to other places.
Order another one and this time I am sure I can get it right.
It be neat if they could put a like phono stereo plug on it for the RS232. The same way I seen old TiVo's did it.
Raymond Day
Wed Apr 08, 2015 4:49 pm
Got my 2nd one today and this time I could solder the RS232 on it better. I got this photo of it so can see the solder job in the bottom right corner of the scan of it.
Raymond Day
Fri Apr 10, 2015 11:41 am
It must be working good. My putty to COM port 3 been on it over a day now. Here is the last part of the boot text and press enter at the end and do uptime command:
procd: - init complete -
[   28.110000] device eth0.1 entered promiscuous mode
[   28.110000] device eth0 entered promiscuous mode
[   28.140000] br-lan: port 1(eth0.1) entered forwarding state
[   28.150000] br-lan: port 1(eth0.1) entered forwarding state
[   30.150000] br-lan: port 1(eth0.1) entered forwarding state
[   32.890000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   32.940000] device wlan0 entered promiscuous mode
[   42.080000] br-lan: port 2(wlan0) entered forwarding state
[   42.090000] br-lan: port 2(wlan0) entered forwarding state
[   42.100000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   44.390000] br-lan: port 2(wlan0) entered forwarding state
BusyBox v1.22.1 (2014-09-17 17:35:56 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
 CHAOS CALMER (v1.0, r42586)
  * 1 1/2 oz Gin            Shake with a glassful
  * 1/4 oz Triple Sec       of broken ice and pour
  * 3/4 oz Lime Juice       unstrained into a goblet.
  * 1 1/2 oz Orange Juice
  * 1 tsp. Grenadine Syrup
root@OpenWrt2:/#
root@OpenWrt2:/# uptime
 05:30:45 up 17:05,  load average: 0.00, 0.01, 0.04
 18:46:55 up 1 day,  6:21,  load average: 0.00, 0.01, 0.04
 07:34:48 up 1 day, 19:09,  load average: 0.00, 0.01, 0.04
root@OpenWrt2:/#
I got it powered with a solar cell right now too.
Greenwire-Elektronik
Sat Apr 11, 2015 2:10 pm
If you want to reuse your vocore, you probably should try the dock or the breakout board, the metal ring around the vias are not very strong ...
Users browsing this forum: Bing [Bot] and 28 guests
