Hello there,
I reveived my vocores and am happy like a little child. I didn't order a dock, because I want to build an own dock with some more possibilities. I know the RT5350 is capable of up to 5 ethernet ports. So here my question:
How can I connect more than just one RJ45 plugs?
more Ethernet ports
Re: more Ethernet ports
VoCore export 2 ethernet port, not the totally 5.
They are P0, P4, you can find it on the pin map. http://vocore.io/wiki/index/id:7
- Pyrofer
Don't forget the magnetics if you are making your own dock.
You can get RJ45 sockets with magnetics built in but don't forget to hook up the 1.8v too or it won't work.
- reinhar2
Thank you very much! Yeah. I know about the Ethernet specifications. So I won't forget it.
- SteeevO
does anyone have en example of the magnetics?
I'm unfamiliar with this.
Thankyou
Thankyou
Jefferynege - Posts: 1
more Ethernet ports
At the moment i do not really mind if its sata 300...i want a cheap controller card which will surely work with 6-8 sata ports..
What about dell perc cards?
Users browsing this forum: No registered users and 191 guests
