Compiling openwrt - error
Kampi
Tue Nov 25, 2014 7:23 am
I want compile a new openwrt, using this Guide:
http://vonger.cn/?p=1585
But I got the error
make -r world: build failed. Please re-run make with V=s to see what's going on
make: *** [world] Fehler 1
Has anybody an idea what is wrong?
darksoul
Re: Compiling openwrt - error
Tue Nov 25, 2014 2:05 pm
Try to build like this: make V=s
You will get log where you have errors.
Kampi
Tue Nov 25, 2014 2:16 pm
found the misstake. I have compiled it with
make -j 4
again and now I got no errors.
Ton
Tue Nov 25, 2014 7:09 pm
Following that tutorial I had two problems:
g++ is needed, but not installed. Do you need to do
sudo apt-get install build-essentials
to get that?
Secondly, I get an error:
/reset.c:90:3: error: implicit declaration of function 'mdelay'
I think the file is in:
/home/ton/openwrt/build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/linux-ramips_rt305x/linux-3.14.18/arch/mips/ralink
I can add #include <linux/delay.h> to reset.c, but from the tutorial I expect the thing to compile without errors?
charliex
Wed Nov 26, 2014 7:34 pm
it should compile without errors, i just pulled the main git tree and compiled it.
-j 4 shouldn't fix errors, all that does is run parallel steps in the makefile where it can.
Peter H
Wed Nov 26, 2014 10:27 pm
It took me a couple of days to get OpenWRT to build, just because one of the GIT repos it needed was inaccessible. You don't say what the original error was, but if it was a network access problem, it might just fix itself after a few hours or days.
Ton
Thu Nov 27, 2014 5:28 pm
Yes, mine is compiling ok now. probably a hickup somewhere
