I am a beginning to use vocore. After I install the openwrt. I am trying to write a simple helloworld program and run the compile command
`find . -name mipsel-openwrt-linux-gcc` -g main.c -o hello
after scp the hello file to vocore /tmp
scp ./hello root@192.168.11.100:/tmp/
then try to run the program:
root@OpenWrt:~# ./hello
sh: ./hello: not found
root@OpenWrt:~#
root@OpenWrt:/tmp# . ./hello
sh: ./hello: line 1: syntax error: unexpected "&" (expecting ")")
root@OpenWrt:/tmp#
please help me to know what's wrong? I follow the instruction from vocore forum. I believe the procedure is correct
vocore beginner helloworld
- pkwok
Re: vocore beginner helloworld
I think the lib changed, please try ldd ./hello, check if any library is missed.
- noblepepper
If you are just getting started with openwrt this may help.
- alexT4I
I'm using ubuntu 16.04 LTS running on a virtual machine in VMWare.
I'm having a similar issue. I'm following this tutorial: http://vonger.cn/?p=1585
When I do the very last step, I get:
I ran ls from the /tmp directory and I see 'hello' there in the listing, in green. I'm very inexperienced with Linux so help is appreciated!
Thanks.
-ash: ./hello: not found
Thanks.
Hi, try to ldd ./hello, check what it returned.
I think it is some library missed.
Users browsing this forum: Google [Bot] and 334 guests
