Thanks for rapid response. I will follow steps let you know the progress.
Thank you, Kris
assembler (mips) as: unrecognized option -EL SOLVED
- Kris
- Kris
Re: assembler (mips) as: unrecognized option -EL SOLVED
Ufffffff ... finaly
Rebuild the development environment as per:
http://noblepepper.com/vocorewiki/doku. ... evelopment
Flashed with newly build system and WORKS. Missing green, yellow lights on the dock ... but is ok.
The problem I had, at least I think it was incorrect library - it should have been:
/lib/ld-uClibc.so.0
Thanks very much for help, your time
With kind regards Kris
P.S. Now can start with my projects ....
/lib/ld-uClibc.so.0
Users browsing this forum: No registered users and 332 guests
