Add 1.2 V DigitalCore switch regulator instead LDO.
silviop
Fri Nov 07, 2014 10:56 am
Semms that rt5350 support external 1.2V switching regulator instead internal LDO.
In future revision should be better use external switch regulator.
lhrossouw
Re: Add 1.2 V DigitalCore switch regulator instead LDO.
Wed Nov 12, 2014 7:07 am
I second this, this will most probably help so that the VoCore does not overheat without a heatsink.
Wed Nov 12, 2014 7:59 am
Already somebody has done that, but result is just same :)
If the power consume can not be lower, all work we did is useless. H = I^2 R.
Anyway, RT5350 is stable under the high temperature, I have tested that for over six days, works normal.
silviop
Wed Nov 12, 2014 8:52 am
Do you know the difference between Linear LDO and switch regulator ?
Tue Nov 18, 2014 12:44 am
OK, I will do some test to check if that really works :)
Peter H
Tue Nov 18, 2014 2:57 am
I'm interested in the 3D printed case that has been designed for VoCore+dock but I wonder what effect this would have on running temperatures. Has anyone tried running VoCore inside one of these cases for a few hours to check whether there are any overheating problems?
lhrossouw
Fri Dec 05, 2014 9:06 am
So I did a comparison between the VoCore using internal 1.2V regulator and a Router with RT5350F chip using external 1.2V regulator.
There is a huge difference.
See attached images taken with a FLIR.
FLIR Images
FLIR Images.jpg (79.05 KiB) Viewed 60146 times
Users browsing this forum: No registered users and 17 guests
