Hello
I'm trying to connect with AP+STA so I can run "opkg update" and install python mini but I'm having difficulty. I believe it connects to my router OK but it doesn't allow the downloads for "opkg update". Here's what iwinfo says, my home network name is "GXS4N":
apcli0 ESSID: "GXS4N"
Access Point: 18:1B:EB:C3:4C:81
Mode: Client Channel: 6 (2.437 GHz)
Tx-Power: 17 dBm Link Quality: unknown/100
Signal: unknown Noise: unknown
Bit Rate: 150.0 MBit/s
Encryption: unknown
Type: wext HW Mode(s): 802.11bg
Hardware: unknown [Generic WEXT]
TX power offset: unknown
Frequency offset: unknown
Supports VAPs: no PHY name: apcli0
apcli1 ESSID: unknown
Access Point: 00:00:00:00:00:00
Encryption: unknown
Supports VAPs: no PHY name: apcli1
ra0 ESSID: "VoCore2"
Access Point: 00:0C:43:E1:76:28
Tx-Power: 17 dBm Link Quality: 10/100
Signal: -256 dBm Noise: -70 dBm
Encryption: unknown
Supports VAPs: no PHY name: ra0
And cat /etc/config/network:
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd47:f447:6340::/48'
config interface 'lan'
option ifname 'eth0.1'
option force_link '1'
option macaddr '00:0c:43:e1:76:28'
option type 'bridge'
option ipaddr '192.168.1.1'
option ip6assign '60'
config interface 'wan'
option ifname 'eth0.2'
option macaddr '00:0c:43:e1:76:29'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '1 2 3 4 6t'
config switch_vlan
option vlan '2'
option ports '0 6t'
AP+STA Help Please SOLVED
- rcpaul
Re: AP+STA Help Please
Are you connected to the internet?
Can opkg find a repo?
Is the package you want available?
root@vocore2:/# ping -c3 google.com
PING google.com (74.125.196.113): 56 data bytes
64 bytes from 74.125.196.113: seq=0 ttl=46 time=34.627 ms
64 bytes from 74.125.196.113: seq=1 ttl=46 time=55.006 ms
64 bytes from 74.125.196.113: seq=2 ttl=46 time=27.283 ms
--- google.com ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 27.283/38.972/55.006 ms
root@vocore2:/# opkg update
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/base/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_base.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/base/Packages.sig.
Signature check passed.
<snip>
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/management/Packages.gz.
Updated list of available packages in /var/opkg-lists/chaos_calmer_management.
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/ramips/mt7628/packages/management/Packages.sig.
root@vocore2:/#
root@vocore2:/# opkg find python*
python - 2.7.9-6 - This package contains the (almost) full Python install.
It's python-light + all other packages.
python-base - 2.7.9-6 - This package contains only the interpreter and the bare minimum
for the interpreter to start.
python-codecs - 2.7.9-6 - Python 2.7 codecs + unicode support
python-compiler - 2.7.9-6 - Python 2.7 compiler module
<snip>
python3-sqlite3 - 3.4.3-2 - Python 3.4 sqlite3 module
python3-unittest - 3.4.3-2 - Python 3.4 unittest module
python3-xml - 3.4.3-2 - Python 3.4 xml libs
root@vocore2:/#
- rcpaul
I think I'm connected to the router but not the internet, how do I troubleshoot now?
- rcpaul
root@OpenWrt:~# ping google.com
PING google.com (216.58.193.206): 56 data bytes
^C
85 packets transmitted, 0 packets received, 100% packet loss
^C
21 packets transmitted, 0 packets received, 100% packet loss
root@OpenWrt:~#
root@OpenWrt:~# iwinfo
apcli0 ESSID: "rfGuest"
Access Point: 88:F0:31:AD:54:E3
Encryption: unknown
Encryption: unknown
Signal: -256 dBm Noise: -83 dBm
Encryption: unknown
^C
^C
root@OpenWrt:~#
Encryption: unknown
Encryption: unknown
Encryption: unknown
What does does /etc/config/wireless look like?
You may want to obfuscate your wifi key, but make sure it matches your router's key.
And what ifconfig say?
root@vocore2:/# cat /etc/config/wireless
config wifi-device radio0
option type ralink
option variant mt7628
option country TW
option hwmode 11g
option htmode HT40
option channel auto
config wifi-iface ap
option device radio0
option mode ap
option network lan
option ifname ra0
option ssid VoCore2
option key '12345678'
option encryption psk2
config wifi-iface sta
option mode sta
option network wwan
option ifname apcli0
option ssid 'elbono-home'
option key 'XXXXXXXX'
root@vocore2:/# ifconfig
apcli0 Link encap:Ethernet HWaddr 02:0C:43:01:76:28
inet addr:192.168.3.240 Bcast:192.168.3.255 Mask:255.255.255.0
inet6 addr: fe80::c:43ff:fe01:7628/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:5 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
br-lan Link encap:Ethernet HWaddr B2:8D:65:22:54:F1
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fdcb:6abb:586f::1/60 Scope:Global
inet6 addr: fe80::b08d:65ff:fe22:54f1/64 Scope:Link
TX packets:2652 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:245168 (239.4 KiB)
eth0 Link encap:Ethernet HWaddr D2:6F:98:55:24:10
inet6 addr: fe80::d06f:98ff:fe55:2410/64 Scope:Link
TX packets:13479 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:4401855 (4.1 MiB)
Interrupt:5
eth0.1 Link encap:Ethernet HWaddr D2:6F:98:55:24:10
TX packets:828 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:88895 (86.8 KiB)
eth0.2 Link encap:Ethernet HWaddr B2:8D:65:22:54:F2
inet6 addr: fe80::b08d:65ff:fe22:54f2/64 Scope:Link
TX packets:12613 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:4253083 (4.0 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:388 errors:0 dropped:0 overruns:0 frame:0
TX packets:388 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:27928 (27.2 KiB) TX bytes:27928 (27.2 KiB)
ra0 Link encap:Ethernet HWaddr 00:0C:43:E1:76:28
inet6 addr: fe80::20c:43ff:fee1:7628/64 Scope:Link
RX packets:482112 errors:0 dropped:0 overruns:0 frame:0
TX packets:26390 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:85782625 (81.8 MiB) TX bytes:604898 (590.7 KiB)
Interrupt:6
- rcpaul
Well I'm glad I bought a bunch of Vocore's cause this is the third one I'm using, I keep disabling the wifi and I don't have the USB to UART converter with me.
Here's the /etc/config/wireless:
root@OpenWrt:~# cat /etc/config/wireless
config wifi-device 'radio0'
option type 'ralink'
option variant 'mt7628'
option country 'CN'
option hwmode '11g'
option htmode 'HT40'
option channel 'auto'
option disabled '0'
config wifi-iface 'ap'
option device 'radio0'
option mode 'ap'
option network 'lan'
option ifname 'ra0'
option ssid 'VoCore2'
option encryption 'none'
config wifi-iface 'sta'
option mode 'sta'
option network 'wwan'
option ifname 'apcli0'
option encryption 'psk'
option ssid 'rfGuest'
option disabled '1'
and ifconfig:
root@OpenWrt:~# ifconfig
br-lan Link encap:Ethernet HWaddr 00:0C:43:E1:76:28
inet6 addr: fd47:f447:6340::1/60 Scope:Global
RX packets:2009 errors:0 dropped:0 overruns:0 frame:0
TX packets:219 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:134559 (131.4 KiB) TX bytes:31127 (30.3 KiB)
eth0 Link encap:Ethernet HWaddr 06:37:37:AF:04:E9
inet6 addr: fe80::437:37ff:feaf:4e9/64 Scope:Link
TX packets:565 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:110719 (108.1 KiB)
Interrupt:5
eth0.1 Link encap:Ethernet HWaddr 06:37:37:AF:04:E9
TX packets:114 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:13305 (12.9 KiB)
eth0.2 Link encap:Ethernet HWaddr 00:0C:43:E1:76:29
inet6 addr: fe80::20c:43ff:fee1:7629/64 Scope:Link
TX packets:85 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:23325 (22.7 KiB)
RX packets:650 errors:0 dropped:0 overruns:0 frame:0
TX packets:650 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:45184 (44.1 KiB) TX bytes:45184 (44.1 KiB)
RX packets:27840 errors:79 dropped:0 overruns:0 frame:0
TX packets:7646 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5574020 (5.3 MiB) TX bytes:242186 (236.5 KiB)
Interrupt:6
option country 'CN'
option hwmode '11g'
option disabled '0'
option mode 'ap'
option ifname 'ra0'
option mode 'sta'
option disabled '1'
and ifconfig:
Interrupt:5
Interrupt:6
I see a couple of things, I'll post details when I'm in front of a computer.
Some more info will help though. Do you know vim? Please post contents of /etc/rc.local. what is rfGuest and is it secured or open?
- rcpaul
I'm not really sure about vim, is it when you vi to a folder and make changes? etc: vi network? If so I'm some what similar with it. I'm not sure how to get to /etc/rc.local but this is what I tried:
root@OpenWrt:~# cd /etc/rc.local
-ash: cd: can't cd to /etc/rc.local
root@OpenWrt:~# cat /etc/rc.local
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
exit 0
root@OpenWrt:/etc# rc.local
-ash: rc.local: not found
root@OpenWrt:/etc#
rfGuest is open but I'm in a hospital right now and it just requires an "accept" screen to access the internet. I know I've been able to use this type of connection with Vocore before. If you look closely I've been moving around while trying to troubleshoot this issue, first was my home network "weefee", then my wife's parents network "GXS4N", and now the hospital "rfGuest". "weefee" and "GXS4N" require keys and "rfGuest" is open and only requires the "accept" screen.
exit 0
root@OpenWrt:/etc#
Vim is "vi improved", on OpenWrt it is a busybox version which is somewhere between vi and vim. It is the default editor in OpenWrt, you'll want to learn it or install pico which is much easier to learn but less powerful. Whatever you do that is for another day, it sounds like you will be more likely to find happiness if I don't tell you to use vim to change a file.
I'm sure it is possible to login to a network with a web accept page but I don't know how and I think it will take a few attempts to get right so I'll stick to networks that don't need that here.
First we need to set up rc.local.
If when you cat the temp file if it doesn't match this exactly erase it with rm /root/temp and start over.
Once it looks good put it together with rc.local:
Now fix your /etc/config/wireless:
Check it to be sure it is right:
And last you need to add wwan to your /etc/config/network:
Check it, at the bottom you should have wwan as a dhcp interface
Go back, double check /etc/rc.local, /etc/config/wireless and /etc/config/network, make sure they are set up like above.
Reboot the VoCore2 and it should bring up the AP and several seconds later connect to the wireless network.
Ifconfig should show an IP address associated with the sta and ping should work.
root@vocore2:/# echo "uci set wireless.sta.disabled=0" > /root/temp
root@vocore2:/# echo "uci commit" >> /root/temp
root@vocore2:/# echo "/etc/init.d/network restart" >> /root/temp
root@vocore2:/# echo "sleep 10" >> /root/temp
root@vocore2:/# echo "uci set wireless.sta.disabled=1" >> /root/temp
root@vocore2:/# cat /root/temp
uci commit
sleep 10
uci commit
root@vocore2:/#
root@vocore2:/# cp /etc/rc.local /root/rc.local
root@vocore2:/# cat /root/temp /root/rc.local > /etc/rc.local
root@vocore2:/# cat /etc/rc.local
uci commit
sleep 10
uci commit
exit 0
uci set wireless.sta.ssid='GXS4N'
uci set wireless.sta.key='SecretKey'
uci commit
option country 'CN'
option hwmode '11g'
option disabled '0'
option mode 'ap'
option ifname 'ra0'
option mode 'sta'
option ssid 'GXS4N'
option key 'SecretKey'
option disabled '1'
root@vocore2:/# uci set network.wwan=interface
root@vocore2:/# uci set network.wwan.proto=dhcp
root@vocore2:/# uci commit
root@vocore2:/# cat /etc/config/network
option ifname 'lo'
<snip>
config switch_vlan
option vlan '2'
option ports '4 6t'
config interface 'wwan'
option proto 'dhcp'
root@vocore2:/# ifconfig |grep -C5 apcli
PING google.com (74.125.138.139): 56 data bytes
64 bytes from 74.125.138.139: seq=0 ttl=46 time=28.796 ms
64 bytes from 74.125.138.139: seq=1 ttl=46 time=42.748 ms
64 bytes from 74.125.138.139: seq=2 ttl=46 time=44.045 ms
round-trip min/avg/max = 28.796/38.529/44.045 ms
root@vocore2:/#
Users browsing this forum: No registered users and 261 guests
