is my vocore2 dead? [SOVLED]
- cory
I disable its wifi by mistake but now when I plug it in win10 pc using USB to USB connection, the pc doesn't show message that there is a new device. Checking device manager show no new port or new device. Same thing with Win 8.1 pc and Win XP pc.. .
Re: is my vocore2 dead?
Check LPT/COM device in device manager. There should be one.I will upload a picture to vocore.io/v2 show that,
- cory
I make a tiny progress. I hook up micro usb to USB of ubuntu host. it shows as /dev/ttyACM0. I also installed Putty on the host. The LED light on vocore2 is purple not green, is it ok? How do I use putty to communicate? I tried many modes, ssh, Serial , ip address, host name, nothing worked.
Ye, if there is a device, you can use linux command "screen" connect to it. This might work: screen /dev/ttyACM0 115200,cs8
You do not have internet connection, so ssh, ip all not work.
- cory
the adventure continue...
I installed screen on ubuntu host then
from ubuntu host I type
stty -F ttyACM0 cs8 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke noflsh -ixon -crtscts
root@cubepc:/# exit // I named it cubepc
// I get in
_______ ________ __
// top command
CPU: 2% usr 2% sys 0% nic 95% idle 0% io 0% irq 0% sirq
Load average: 0.10 0.12 0.13 1/43 4049
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
315 2 root SW 0 0% 1% [kworker/u2:3]
3916 2993 root R 1488 1% 0% top
1013 918 root S 1484 1% 0% udhcpc -p /var/run/udhcpc-eth0.2.pid
1310 1 nobody S 992 1% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq
1044 2 root SW 0 0% 0% [RtmpMlmeTask]
1280 1 root S 7688 6% 0% /usr/bin/shairport-sync -c /var/etc/s
1138 1 root S 3188 3% 0% /usr/sbin/nmbd -F
1137 1 root S 3096 2% 0% /usr/sbin/smbd -F
1145 1 nobody S 2156 2% 0% avahi-daemon: running [cubepc.local]
1108 1 root S 1736 1% 0% /usr/sbin/dbus-daemon --system
4049 918 root S 1688 1% 0% /usr/sbin/pppd nodetach ipparam minic
1098 1 root S 1624 1% 0% /usr/sbin/uhttpd -f -h /www -r cubepc
883 1 root S 1568 1% 0% /sbin/rpcd
918 1 root S 1560 1% 0% /sbin/netifd
2993 1 root S 1488 1% 0% /bin/ash --login
1267 1 root S 1484 1% 0% /usr/sbin/ntpd -n -S /usr/sbin/ntpd-h
1 0 root S 1440 1% 0% /sbin/procd
933 1 root S 1192 1% 0% /usr/sbin/odhcpd
1052 1 root S 1148 1% 0% /usr/sbin/dropbear -F -P /var/run/dro
^C873 1 root S 1056 1% 0% /sbin/logd -S 16
But how do do i restore the wireless feature?
// I get in
_______ ________ __
// top command
You can also reboot the VoCore2 and reset everything back like it was when you got it using failsafe mode
Now you can reset to the last loaded system with
Now you will be back to then default settings like when you got it.
# reboot
# firstboot -y
# reboot
- cory
I tried reboot, f, firstboot, reboot again and again then I suddenly saw vocore2 online. I did ctrl + D to get out of busybox session. I shutdown the Ubuntu host before unplug vocore2 from it. Now vocore2 hot spot is on again, thanks!!!!
Re: is my vocore2 dead? [SOVLED]
I'm not sure how you got it unless you figured out that the firstboot command wasn't exactly correct. This is a bug in Chaos Calmer-
The command you need is
firstboot -y
Users browsing this forum: No registered users and 54 guests
