I'm trying to connect to Vocore2 by TTY to enable the wifi on my Vocore but I keep getting an error message and I don't know whats going on.
Kermit> connect
Connecting to /dev/tty.usbserial, speed 115200
Escape character: Ctrl-\ (ASCII 28, FS): enabled
Type the escape character followed by C to get back,
or followed by ? to see other options.
*** Warning - bad CRC, using default environment
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is low
You chose 3
0
3: System Boot system code via Flash.
Image Name: MIPS OpenWrt Linux-3.18.29
Data Size: 1146069 Bytes = 1.1 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
No initrd
Starting kernel ...
[ 0.000000] Linux version 3.18.29 (vocore@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49378) ) #22 Sun Oct 16 21:00:17 CST 2016
[ 0.000000] Board has DDR2
[ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
[ 0.000000] MIPS: machine is VoCore2
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x07ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] node 0: [mem 0x00000000-0x07ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x07ffffff]
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS2,115200 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00061146
[ 0.000000] Readback ErrCtl register=00061146
[ 0.000000] Memory: 126340K/131072K available (2530K kernel code, 131K rwdata, 520K rodata, 136K init, 186K bss, 4732K reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:256
[ 0.000000] intc: using register map from devicetree
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] clocksource_of_init: no matching clocksources found
[ 0.000000] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[ 0.060000] pid_max: default: 32768 minimum: 301
[ 0.060000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070000] pinctrl core: initialized pinctrl subsystem
[ 0.080000] NET: Registered protocol family 16
[ 0.100000] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.110000] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.120000] Switched to clocksource MIPS
[ 0.120000] NET: Registered protocol family 2
[ 0.130000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.130000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.140000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.140000] TCP: reno registered
[ 0.150000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.150000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.160000] NET: Registered protocol family 1
[ 0.170000] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.180000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.190000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.200000] msgmni has been set to 246
[ 0.210000] io scheduler noop registered
[ 0.210000] io scheduler deadline registered (default)
[ 0.220000] gdma-mt7628 10002800.gdma: revision: 3, channels: 16
[ 0.230000] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.230000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.240000] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.250000] console [ttyS2] disabled
[ 0.260000] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.270000] console [ttyS2] enabled
[ 0.270000] bootconsole [early0] disabled
[ 0.280000] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.290000] m25p80 spi32766.0: found w25q128, expected en25q64
[ 0.300000] m25p80 spi32766.0: w25q128 (16384 Kbytes)
[ 0.300000] m25p80 spi32766.0: using chunked io
[ 0.310000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.320000] Creating 4 MTD partitions on "spi32766.0":
[ 0.320000] 0x000000000000-0x000000030000 : "u-boot"
[ 0.330000] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.330000] 0x000000040000-0x000000050000 : "factory"
[ 0.340000] 0x000000050000-0x000001000000 : "firmware"
[ 0.410000] 2 uimage-fw partitions found on MTD device firmware
[ 0.410000] 0x000000050000-0x000000167d15 : "kernel"
[ 0.420000] 0x000000167d15-0x000001000000 : "rootfs"
[ 0.420000] mtd: device 5 (rootfs) set to be root filesystem
[ 0.430000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.440000] 0x0000006a0000-0x000001000000 : "rootfs_data"
[ 0.450000] ralink_soc_eth 10100000.ethernet: generated random MAC address 76:06:2f:92:e1:1a
[ 0.460000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[ 0.470000] mt7621_wdt 10000120.watchdog: Initialized
[ 0.480000] TCP: cubic registered
[ 0.480000] NET: Registered protocol family 17
[ 0.480000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.500000] 8021q: 802.1Q VLAN Support v1.8
[ 0.520000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.520000] Freeing unused kernel memory: 136K (8031e000 - 80340000)
[ 2.310000] init: Console is alive
[ 2.320000] init: - watchdog -
[ 5.840000] usbcore: registered new interface driver usbfs
[ 5.850000] usbcore: registered new interface driver hub
[ 5.850000] usbcore: registered new device driver usb
[ 5.870000] exFAT: Version 1.2.9
[ 5.920000] SCSI subsystem initialized
[ 5.930000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.940000] ehci-platform: EHCI generic platform driver
[ 5.950000] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 5.960000] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 5.960000] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 5.970000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 5.980000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 6.010000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 6.010000] hub 1-0:1.0: USB hub found
[ 6.020000] hub 1-0:1.0: 1 port detected
[ 6.020000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 6.030000] ohci-platform: OHCI generic platform driver
[ 6.040000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 6.040000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 6.050000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 6.120000] hub 2-0:1.0: USB hub found
[ 6.120000] hub 2-0:1.0: 1 port detected
[ 6.140000] MTK MSDC device init.
[ 6.180000] mtk-sd: MediaTek MT6575 MSDC Driver
[ 6.180000] sdhci: Secure Digital Host Controller Interface driver
[ 6.190000] sdhci: Copyright(c) Pierre Ossman
[ 6.200000] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.210000] usbcore: registered new interface driver usb-storage
[ 6.220000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.220000] mmc0: error -22 whilst initialising SDIO card
[ 6.230000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.240000] mmc0: error -22 whilst initialising MMC card
[ 6.280000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.290000] mmc0: error -22 whilst initialising SDIO card
[ 6.290000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.300000] mmc0: error -22 whilst initialising MMC card
[ 6.350000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.360000] mmc0: error -22 whilst initialising SDIO card
[ 6.360000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.370000] mmc0: error -22 whilst initialising MMC card
[ 6.440000] init: - preinit -
[ 7.440000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.450000] mmc0: error -22 whilst initialising SDIO card
[ 7.470000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.470000] mmc0: error -22 whilst initialising MMC card
[ 7.540000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.550000] mmc0: error -22 whilst initialising SDIO card
[ 7.740000] rt305x-esw 10110000.esw: link changed 0x00
[ 7.890000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.890000] mmc0: error -22 whilst initialising MMC card
[ 7.940000] random: mktemp urandom read with 13 bits of entropy available
[ 7.960000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.960000] mmc0: error -22 whilst initialising SDIO card
[ 7.980000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.980000] mmc0: error -22 whilst initialising MMC card
[ 9.050000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.060000] mmc0: error -22 whilst initialising SDIO card
[ 9.060000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.070000] mmc0: error -22 whilst initialising MMC card
[ 9.110000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.120000] mmc0: error -22 whilst initialising SDIO card
[ 9.120000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.130000] mmc0: error -22 whilst initialising MMC card
[ 9.180000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.190000] mmc0: error -22 whilst initialising SDIO card
[ 9.190000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.200000] mmc0: error -22 whilst initialising MMC card
[ 10.250000] mtk-sd 10130000.sdhci: no support for card's volts
[ 10.260000] mmc0: error -22 whilst initialising SDIO card
Help with TTY connection, error
- rcpaul
- rcpaul
Re: Help with TTY connection, error
Still need help with this, two of my Vocore's are bricked because I can't enable the Wifi.
- cory
As you can see in my thread "is my vocore2 dead? [SOVLED]" I revived it thru a Linux machine for the first time. But since then I go back to my window lap laptop and revive it many times, more than 5 times, all I need is to install usbttl drive from http://vonger.cn/misc/vocore2/tools/usb2ttl.zip then install putty to log on to vocore2 and do reboot, f, firstboot -y, then reboot again as per noblepepper instruction. It took less than 5m to revive it once I remember the sequence.
- rcpaul
Im able to connect tty but as soon as the kernel starts the error message keeps coming up, how do I stop that and inout the command to reboot?
- cory
try to issue sysreq by Alt + sysreq or Fn + sysreq or ctrl+alt+d
https://en.wikipedia.org/wiki/Magic_SysRq_key
@Cory - Interesting alternative, I don't think OpenWrt is built with that enabled but I am going to play with the idea to see what is possible.
@rcpaul - What you can do is press [Enter] to bring up the banner and command prompt (it will be hidden in the garbage)
Then type rmmod mtk-sd, you have to do it blindly while garbage continues. It may take two or three tries. This will usually stop the garbage but I have had times it would not.
If you can't stop the garbage it looks like you can get into u-boot so you should use that to load the 20161224.bin image, go ahead and download it to your computer.
If you are on an Airplay (this shouldn't happen on an Ultimate) use the USB Storage option.
If you are on a bare board, you are stuck with the serial load option (0 on the menu). At 115200 baud this is very slow, you will need to be patient. For a bare board I have been very lucky using a PL2303 based USB/UART at 460800 baud and it takes less than 5 minutes. This isn't guaranteed, but give it a try. Here's how:
On the u-boot menu take option 4:
Set the baudrate to 460800:
Use [ctrl]\ c to get out to kermit's command line, change the speed and reconnect and press [Enter] like u-boot asked:
u-boot is using the last [Enter] to detect that you changed speed in Kermit. If it doesn't get it at the correct baudrate you just power cycle and go about your business at 115200.
Now save the new speed so u-boot will continue to use it when you reboot:
Don't forget this step or you'll be back at 115200 when you reboot (I usually forget and have to do it all again)
Now reboot and follow the normal instructions for loading over serial using option 0:
Use [ctrl]\ c again to send the image and reconnect, a few minutes later you'll be running the new image
DRAM component: 512 Mbits DDR, width 16
DRAM bus: 16 bit
Total memory: 64 MBytes
Date:Jun 25 2016 Time:09:25:16
GPIO 46 is low
8
You chose 4
0
4: System Enter Boot Command Line Interface.
U-Boot 1.1.3 (Jun 25 2016 - 09:25:16)
VoCore2 >
VoCore2 > setenv baudrate 460800
## Switch baudrate to 460800 bps and press ENTER ...
(Back at elbono-bigguy.elbono.com)
Kermit> set speed 460800
/dev/ttyUSB1, 460800 bps
Kermit> connect
Connecting to /dev/ttyUSB1, speed 460800
VoCore2 >
VoCore2 > saveenv
Saving Environment to SPI Flash...
Erasing SPI Flash...
Writing to SPI Flash...
done
VoCore2 >
VoCore2 > reset
Software System Reset Occurred
DRAM bus: 16 bit
GPIO 46 is low
8
You chose 0
0
0: System Load Linux then write to Flash via Serial.
## Ready for binary (kermit) download to 0x80100000 at 460800 bps...
Kermit> send 20161224.bin
Kermit> connect
## Total Size = 0x006c0004 = 7077892 Bytes
## Start Addr = 0x80100000
Done!
DRAM bus: 16 bit
- rcpaul
noblepepper I can get into the command prompt, what is the easiest way to enable the wifi?
I tired changing the baud rate but it didn't work for me so I'm hoping to enable the wifi and load the firmware with Luci.
I think using the serial upload in u-boot will be your easiest option even if you use 115200 baud, it just takes longer.
If you want to do it from where you are you need /etc/config/wireless to look like this:
Then restart the network:
The VoCore2 AP should be up, connect to it.
You should be able to find Luci at 192.168.61.1 with your web browser, use it to upload 20161224.bin make sure the keep settings box is NOT checked.
You should come back up with a VoCore2 ready to configure without all the aggravating "no support for card volts" crap and with the latest firmware.
Now follow the instructions for "Setup AP + STA Mode" on the product page. Vonger has changed them, much easier to follow now.
config wifi-device 'radio0'
option type 'ralink'
option variant 'mt7628'
option country 'CN'
option hwmode '11g'
option htmode 'HT40'
option channel 'auto'
option disabled '0'
config wifi-iface 'ap'
option device 'radio0'
option mode 'ap'
option network 'lan'
option ifname 'ra0'
option ssid 'VoCore2'
option encryption 'none'
config wifi-iface 'sta'
option mode 'sta'
option network 'wwan'
option ifname 'apcli0'
option ssid 'UplinkAp'
option key 'SecretKey'
option encryption 'psk'
option disabled '1'
root@OpenWrt:/# /etc/init.d/network restart
[ 393.870000] br-lan: port 2(ra0) entered disabled state
[ 393.880000] br-lan: port 1(eth0.1) entered disabled state
[ 393.890000] device eth0.1 left promiscuous mode
[ 393.890000] br-lan: port 1(eth0.1) entered disabled state
[ 393.900000] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[ 393.930000] device ra0 left promiscuous mode
[ 393.930000] br-lan: port 2(ra0) entered disabled state
[ 394.160000] device eth0 left promiscuous mode
root@OpenWrt:/# [ 395.960000] device eth0.1 entered promiscuous mode
[ 395.960000] device eth0 entered promiscuous mode
[ 395.980000] br-lan: port 1(eth0.1) entered forwarding state
[ 396.770000] device ra0 entered promiscuous mode
[ 396.770000] br-lan: port 2(ra0) entered forwarding state
[ 396.780000] br-lan: port 2(ra0) entered forwarding state
[ 397.980000] br-lan: port 1(eth0.1) entered forwarding state
[ 398.780000] br-lan: port 2(ra0) entered forwarding state
- rcpaul
Not exactly sure how I did it but I was able to enable the wifi on all my Vocore's.
Thanks again for all your help!
I did try to send you a pm but its just staying in my outbox?
It came through, I'm not impressed with phpBB's PM module it does funky things.
Make sure you have Allow users to send you private messages: set to Yes. It is under Board preferences in the User Control panel.
Users browsing this forum: No registered users and 30 guests
