Smaller docks (like audio dock)
murraythegoz
Fri Dec 30, 2016 10:54 am
I just bought a vocore2+ultimate dock.
Then I saw the audio dock.
For some project, I would find useful such smaller docks, like one without ethernet or full-size usb, but with microusb (for powering on and ethernet-over-gadget) and microsd reader.
This would make such dock still thin (like the audio one), albeit with a bunch of basic io and storage.
If enough are interested, we could ask vonger to make it available.
Or make ourselves.
thank you in advance
m.
Re: Smaller docks (like audio dock)
Fri Dec 30, 2016 12:41 pm
We will have this option soon(should in two or three days).Image
There are two options, one USB power board, you can directly connect vocore to usb power source; one is tf card board, used to connect with tf card.
murraythegoz
Tue Jan 03, 2017 4:57 pm
This is great news.
I will keep an eye on this, and order one (or two, or more) as soon as it is available.
Thank you
m.
murraythegoz
Thu Jan 05, 2017 11:00 am
Just three more questions:
1) as far as I see, in the upcoming docks both USB data and power are connected. Am I right?
2) if data is connected, is host/otg or guest (or both) available
3) does the openwrt kernel provided with vocore2 support usb ethernet gadget?
I wish I can use the usb network gadget, to have a (smaller, compared to full fledged RJ45 ethernet) network interface to the Vocore2, alternative to wifi.
thank you
m.
Thu Jan 05, 2017 11:45 pm
only power connected, no data.
murraythegoz
Tue Jan 10, 2017 11:48 am
ok thank you.
will work out data lines myself.
(gonna use a micro-usb female connector instead of a USB-A male for my project)
I saw soldering on 2x GND and 2x 5V power.
Will soldering a 1x GND and 1x 5V power suffice to boot the VoCore2?
pflynn
Fri Mar 03, 2017 8:06 pm
Can I ask,
Why is power only connected to mircoUSB in this case?
When configured with the DOCK, the microUSB is both power and serial comm port...
Is there a reason not to solder to the data port pins?
thanks!
Sun Mar 05, 2017 12:31 pm
pflynn wrote:Can I ask,
thanks!
USB data wires on VoCore2 is host mode, not device mode, so connect it is useless.
Users browsing this forum: No registered users and 476 guests
