Setup AP + STA Mode
kosmonaut pirx
Re: Setup AP + STA Mode
Mon Jan 09, 2017 10:29 pm
Here's mine:
root@pepe:/# cat /etc/config/wireless
config wifi-device 'radio0'
option type 'ralink'
option variant 'mt7628'
option country 'DE'
option hwmode '11g'
option htmode 'HT40'
option channel 'auto'
option disabled '0'
config wifi-iface 'ap'
option device 'radio0'
option mode 'ap'
option network 'lan'
option ifname 'ra0'
option ssid 'VoCore2'
option encryption 'none'
option disabled '0'
config wifi-iface 'sta'
option mode 'sta'
option network 'wifi_sta'
option ifname 'apcli0'
option key 'thisIsMyWpa2Psk'
option encryption 'psk2+ccmp'
option disabled '0'
option ssid 'thisIsMySsid'
Last line is important for you, should contain your APs ssid
herci
Tue Jan 10, 2017 4:35 pm
I see this after the command
root@OpenWrt:/# cat /etc/config/wireless
option country 'CN'
option hwmode '11g'
option disabled '0'
option mode 'ap'
option ifname 'ra0'
option mode 'sta'
option network 'wwan'
option encryption 'psk'
option ssid '[telenet-apn-D4F49]'
option key '[my password]'
option disabled '1'
kosmonaut pirx
Tue Jan 10, 2017 9:08 pm
As written, remove the square brackets and re-enable the interface. Otherwise there'll be no progress at all
herci
Tue Jan 10, 2017 9:33 pm
now I got
option country 'CN'
option hwmode '11g'
option disabled '0'
option mode 'ap'
option ifname 'ra0'
option mode 'sta'
option ssid 'telenet-apn-D4F49'
option key 'mypassword'
option disabled '1'
kosmonaut pirx
Tue Jan 10, 2017 9:41 pm
Getting better. Still disabled, though.
Re-enable, restart 'wifi' and watch logread output for association messages.
herci
Tue Jan 10, 2017 9:45 pm
What do you mean with re-enable?
Is that changing the last option disabled from 1 to 0? (Sorry, I know nothing about all this)
kosmonaut pirx
Tue Jan 10, 2017 9:51 pm
No problem.
Yes, right. Last line 1 to 0. As in my example.
herci
Tue Jan 10, 2017 10:30 pm
I'm going mad with this thing, I hardly know any commands,
I messed it up completely, I can't seem to go up in the menu/list
I have loads of white spaces I can't remove and I must have removed a disabled line in the second block
I don't know how to fix this or even have to save this. Couldn't get out of the menu and started trying all sorts of stuff....
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/# cat etc/config/wireless
option country 'CN'
option hwmode '11g'
option disabled '0'
option mode 'ap'
option ifname 'ra0'
option mode 'sta'
option key 'key'
option disabled '0'
root@OpenWrt:/#
and the wifi signal is gone because of the erased command I guess
edit: signal is back now
can't get above the root@openwrt line with the arrows
herci
Tue Jan 10, 2017 10:49 pm
_______ ________ __
* 1 1/2 oz Gin Shake with a glassful
* 1/4 oz Triple Sec of broken ice and pour
* 3/4 oz Lime Juice unstrained into a goblet.
* 1 1/2 oz Orange Juice
* 1 tsp. Grenadine Syrup
root@OpenWrt:~# logread -f
Tue Jan 10 22:37:16 2017 authpriv.info dropbear[2135]: Child connection from 192 .168.1.146:49248
Tue Jan 10 22:37:22 2017 authpriv.notice dropbear[2135]: Password auth succeeded for 'root' from 192.168.1.146:49248
Tue Jan 10 22:37:30 2017 daemon.notice netifd: Network device 'ra0' link is down
Tue Jan 10 22:37:30 2017 daemon.info avahi-daemon[1137]: Interface ra0.IPv6 no l onger relevant for mDNS.
Tue Jan 10 22:37:30 2017 daemon.info avahi-daemon[1137]: Leaving mDNS multicast group on interface ra0.IPv6 with address fe80::bad8:12ff:fe67:13e0.
Tue Jan 10 22:37:30 2017 daemon.info avahi-daemon[1137]: Withdrawing address rec ord for fe80::bad8:12ff:fe67:13e0 on ra0.
Tue Jan 10 22:37:30 2017 kern.info kernel: [ 272.190000] br-lan: port 2(ra0) en tered disabled state
Tue Jan 10 22:37:30 2017 kern.info kernel: [ 272.220000] device ra0 left promis cuous mode
Tue Jan 10 22:37:30 2017 kern.info kernel: [ 272.220000] br-lan: port 2(ra0) en tered disabled state
Tue Jan 10 22:37:30 2017 daemon.notice netifd: radio0 (2161): Interface doesn't accept private ioctl...
Tue Jan 10 22:37:30 2017 daemon.notice netifd: radio0 (2161): set (8BE2): Invali d argument
Tue Jan 10 22:37:30 2017 daemon.notice netifd: Network device 'ra0' link is up
Tue Jan 10 22:37:30 2017 kern.info kernel: [ 272.430000] device ra0 entered pro miscuous mode
Tue Jan 10 22:37:31 2017 kern.info kernel: [ 273.200000] br-lan: port 2(ra0) en tered forwarding state
Tue Jan 10 22:37:31 2017 daemon.info avahi-daemon[1137]: Joining mDNS multicast group on interface ra0.IPv6 with address fe80::bad8:12ff:fe67:13e0.
Tue Jan 10 22:37:31 2017 daemon.info avahi-daemon[1137]: New relevant interface ra0.IPv6 for mDNS.
Tue Jan 10 22:37:31 2017 daemon.info avahi-daemon[1137]: Registering new address record for fe80::bad8:12ff:fe67:13e0 on ra0.*.
Tue Jan 10 22:37:32 2017 kern.info ap_client: apcli0 is not associated
Tue Jan 10 22:37:32 2017 kern.info ap_client: Scanning for networks...
Tue Jan 10 22:37:33 2017 kern.info kernel: [ 275.200000] br-lan: port 2(ra0) en tered forwarding state
Tue Jan 10 22:37:33 2017 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192 .168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:37:33 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168 .1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:37:34 2017 daemon.warn odhcpd[935]: DHCPV6 CONFIRM IA_NA from 0001 00011f69939df0def1bc2580 on br-lan: not on-link fd1c:5a88:47dd::753/128
Tue Jan 10 22:37:34 2017 daemon.warn odhcpd[935]: DHCPV6 SOLICIT IA_NA from 0001 00011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:37:34 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresse s
Tue Jan 10 22:37:34 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 0 a ddresses
Tue Jan 10 22:37:34 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 add resses
Tue Jan 10 22:37:34 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 ad dresses
Tue Jan 10 22:37:35 2017 daemon.warn odhcpd[935]: DHCPV6 REQUEST IA_NA from 0001 00011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:37:35 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresse s
Tue Jan 10 22:37:35 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 1 a ddresses
Tue Jan 10 22:37:35 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 add resses
Tue Jan 10 22:37:35 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 ad dresses
Tue Jan 10 22:37:37 2017 kern.info ap_client: Found network - 1 telenet-apn-D4F4 9 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Tue Jan 10 22:37:37 2017 kern.info ap_client: Found network - 6 WiFi-2.4-AA26 00 :37:b7:74:aa:2c WPA2PSK
Tue Jan 10 22:37:37 2017 kern.info ap_client: Found network, trying to associate (essid: telenet-apn-D4F49, bssid: telenet-apn-D4F49, channel: 1, enc: WPA1PSKWP A2PSK, crypto: TKIPAES)
Tue Jan 10 22:37:37 2017 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192 .168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:37:37 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168 .1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:37:38 2017 daemon.warn odhcpd[935]: DHCPV6 CONFIRM IA_NA from 000100011f69939df0def1bc2580 on br-lan: not on-link fd1c:5a88:47dd::753/128
Tue Jan 10 22:37:38 2017 daemon.warn odhcpd[935]: DHCPV6 SOLICIT IA_NA from 000100011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:37:38 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresses
Tue Jan 10 22:37:38 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 0 addresses
Tue Jan 10 22:37:38 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 addresses
Tue Jan 10 22:37:38 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 addresses
Tue Jan 10 22:37:39 2017 daemon.warn odhcpd[935]: DHCPV6 REQUEST IA_NA from 000100011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:37:39 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresses
Tue Jan 10 22:37:39 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 1 addresses
Tue Jan 10 22:37:39 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 addresses
Tue Jan 10 22:37:39 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 addresses
Tue Jan 10 22:37:41 2017 daemon.info dnsmasq-dhcp[1291]: DHCPINFORM(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:37:41 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:37:47 2017 kern.info ap_client: apcli0 is associated
Tue Jan 10 22:38:18 2017 daemon.notice netifd: Network device 'ra0' link is down
Tue Jan 10 22:38:18 2017 daemon.info avahi-daemon[1137]: Interface ra0.IPv6 no longer relevant for mDNS.
Tue Jan 10 22:38:18 2017 daemon.info avahi-daemon[1137]: Leaving mDNS multicast group on interface ra0.IPv6 with address fe80::bad8:12ff:fe67:13e0.
Tue Jan 10 22:38:18 2017 daemon.info avahi-daemon[1137]: Withdrawing address record for fe80::bad8:12ff:fe67:13e0 on ra0.
Tue Jan 10 22:38:18 2017 kern.info kernel: [ 320.270000] br-lan: port 2(ra0) entered disabled state
Tue Jan 10 22:38:18 2017 kern.info kernel: [ 320.290000] device ra0 left promiscuous mode
Tue Jan 10 22:38:18 2017 kern.info kernel: [ 320.300000] br-lan: port 2(ra0) entered disabled state
Tue Jan 10 22:38:18 2017 daemon.notice netifd: radio0 (2220): Interface doesn't accept private ioctl...
Tue Jan 10 22:38:18 2017 daemon.notice netifd: radio0 (2220): set (8BE2): Invalid argument
Tue Jan 10 22:38:18 2017 daemon.notice netifd: Network device 'ra0' link is up
Tue Jan 10 22:38:18 2017 kern.info kernel: [ 320.510000] device ra0 entered promiscuous mode
Tue Jan 10 22:38:19 2017 kern.info kernel: [ 321.280000] br-lan: port 2(ra0) entered forwarding state
Tue Jan 10 22:38:19 2017 daemon.info avahi-daemon[1137]: Joining mDNS multicast group on interface ra0.IPv6 with address fe80::bad8:12ff:fe67:13e0.
Tue Jan 10 22:38:19 2017 daemon.info avahi-daemon[1137]: New relevant interface ra0.IPv6 for mDNS.
Tue Jan 10 22:38:19 2017 daemon.info avahi-daemon[1137]: Registering new address record for fe80::bad8:12ff:fe67:13e0 on ra0.*.
Tue Jan 10 22:38:21 2017 kern.info kernel: [ 323.280000] br-lan: port 2(ra0) entered forwarding state
Tue Jan 10 22:38:21 2017 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:38:21 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:38:22 2017 daemon.warn odhcpd[935]: DHCPV6 CONFIRM IA_NA from 000100011f69939df0def1bc2580 on br-lan: not on-link fd1c:5a88:47dd::753/128
Tue Jan 10 22:38:22 2017 daemon.warn odhcpd[935]: DHCPV6 SOLICIT IA_NA from 000100011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:38:22 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresses
Tue Jan 10 22:38:22 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 0 addresses
Tue Jan 10 22:38:22 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 addresses
Tue Jan 10 22:38:22 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 addresses
Tue Jan 10 22:38:23 2017 daemon.warn odhcpd[935]: DHCPV6 REQUEST IA_NA from 000100011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:38:23 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresses
Tue Jan 10 22:38:23 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 1 addresses
Tue Jan 10 22:38:23 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 addresses
Tue Jan 10 22:38:23 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 addresses
Tue Jan 10 22:38:26 2017 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:38:26 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:38:43 2017 daemon.info dnsmasq-dhcp[1291]: DHCPINFORM(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:38:43 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:39:46 2017 daemon.info dnsmasq-dhcp[1291]: DHCPINFORM(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:39:46 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:42:35 2017 daemon.info dnsmasq-dhcp[1291]: DHCPINFORM(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:42:35 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:44:17 2017 authpriv.info dropbear[2135]: Exit (root): Exited normally
Tue Jan 10 22:44:34 2017 authpriv.info dropbear[2253]: Child connection from 192.168.1.146:49249
Tue Jan 10 22:44:39 2017 authpriv.notice dropbear[2253]: Password auth succeeded for 'root' from 192.168.1.146:49249
Tue Jan 10 22:44:42 2017 daemon.notice netifd: Network device 'ra0' link is down
Tue Jan 10 22:44:42 2017 daemon.info avahi-daemon[1137]: Interface ra0.IPv6 no longer relevant for mDNS.
Tue Jan 10 22:44:42 2017 daemon.info avahi-daemon[1137]: Leaving mDNS multicast group on interface ra0.IPv6 with address fe80::bad8:12ff:fe67:13e0.
Tue Jan 10 22:44:42 2017 kern.info kernel: [ 704.240000] br-lan: port 2(ra0) entered disabled state
Tue Jan 10 22:44:42 2017 daemon.info avahi-daemon[1137]: Withdrawing address record for fe80::bad8:12ff:fe67:13e0 on ra0.
Tue Jan 10 22:44:42 2017 kern.info kernel: [ 704.260000] device ra0 left promiscuous mode
Tue Jan 10 22:44:42 2017 kern.info kernel: [ 704.260000] br-lan: port 2(ra0) entered disabled state
Tue Jan 10 22:44:42 2017 daemon.notice netifd: radio0 (2280): Interface doesn't accept private ioctl...
Tue Jan 10 22:44:42 2017 daemon.notice netifd: radio0 (2280): set (8BE2): Invalid argument
Tue Jan 10 22:44:42 2017 daemon.notice netifd: Network device 'ra0' link is up
Tue Jan 10 22:44:42 2017 kern.info kernel: [ 704.480000] device ra0 entered promiscuous mode
Tue Jan 10 22:44:43 2017 kern.info kernel: [ 705.250000] br-lan: port 2(ra0) entered forwarding state
Tue Jan 10 22:44:44 2017 daemon.info avahi-daemon[1137]: Joining mDNS multicast group on interface ra0.IPv6 with address fe80::bad8:12ff:fe67:13e0.
Tue Jan 10 22:44:44 2017 daemon.info avahi-daemon[1137]: New relevant interface ra0.IPv6 for mDNS.
Tue Jan 10 22:44:44 2017 daemon.info avahi-daemon[1137]: Registering new address record for fe80::bad8:12ff:fe67:13e0 on ra0.*.
Tue Jan 10 22:44:45 2017 kern.info kernel: [ 707.250000] br-lan: port 2(ra0) entered forwarding state
Tue Jan 10 22:44:45 2017 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:44:45 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:44:46 2017 daemon.warn odhcpd[935]: DHCPV6 CONFIRM IA_NA from 000100011f69939df0def1bc2580 on br-lan: not on-link fd1c:5a88:47dd::753/128
Tue Jan 10 22:44:46 2017 daemon.warn odhcpd[935]: DHCPV6 SOLICIT IA_NA from 000100011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:44:46 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresses
Tue Jan 10 22:44:46 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 0 addresses
Tue Jan 10 22:44:46 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 addresses
Tue Jan 10 22:44:46 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 addresses
Tue Jan 10 22:44:47 2017 daemon.notice netifd: Network device 'ra0' link is down
Tue Jan 10 22:44:47 2017 daemon.info avahi-daemon[1137]: Interface ra0.IPv6 no longer relevant for mDNS.
Tue Jan 10 22:44:47 2017 daemon.info avahi-daemon[1137]: Leaving mDNS multicast group on interface ra0.IPv6 with address fe80::bad8:12ff:fe67:13e0.
Tue Jan 10 22:44:47 2017 daemon.info avahi-daemon[1137]: Withdrawing address record for fe80::bad8:12ff:fe67:13e0 on ra0.
Tue Jan 10 22:44:47 2017 kern.info kernel: [ 708.950000] br-lan: port 2(ra0) entered disabled state
Tue Jan 10 22:44:47 2017 kern.info kernel: [ 708.970000] device ra0 left promiscuous mode
Tue Jan 10 22:44:47 2017 kern.info kernel: [ 708.980000] br-lan: port 2(ra0) entered disabled state
Tue Jan 10 22:44:47 2017 daemon.notice netifd: radio0 (2328): Interface doesn't accept private ioctl...
Tue Jan 10 22:44:47 2017 daemon.notice netifd: radio0 (2328): set (8BE2): Invalid argument
Tue Jan 10 22:44:47 2017 daemon.notice netifd: Network device 'ra0' link is up
Tue Jan 10 22:44:47 2017 kern.info kernel: [ 709.200000] device ra0 entered promiscuous mode
Tue Jan 10 22:44:47 2017 kern.info ap_client: apcli0 is not associated
Tue Jan 10 22:44:47 2017 kern.info ap_client: Scanning for networks...
Tue Jan 10 22:44:48 2017 kern.info kernel: [ 709.960000] br-lan: port 2(ra0) entered forwarding state
Tue Jan 10 22:44:49 2017 daemon.info avahi-daemon[1137]: Joining mDNS multicast group on interface ra0.IPv6 with address fe80::bad8:12ff:fe67:13e0.
Tue Jan 10 22:44:49 2017 daemon.info avahi-daemon[1137]: New relevant interface ra0.IPv6 for mDNS.
Tue Jan 10 22:44:49 2017 daemon.info avahi-daemon[1137]: Registering new address record for fe80::bad8:12ff:fe67:13e0 on ra0.*.
Tue Jan 10 22:44:50 2017 kern.info kernel: [ 711.960000] br-lan: port 2(ra0) entered forwarding state
Tue Jan 10 22:44:50 2017 daemon.info dnsmasq-dhcp[1291]: DHCPINFORM(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:44:50 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:44:50 2017 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:44:50 2017 daemon.warn odhcpd[935]: DHCPV6 REQUEST IA_NA from 000100011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:44:50 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresses
Tue Jan 10 22:44:50 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 1 addresses
Tue Jan 10 22:44:50 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 addresses
Tue Jan 10 22:44:50 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 addresses
Tue Jan 10 22:44:52 2017 kern.info ap_client: Found network - 1 WiFi-2.4-AA26 00:37:b7:74:aa:2c WPA2PSK
Tue Jan 10 22:44:52 2017 kern.info ap_client: Found network - 1 telenet-apn-D4F49 ac:f1:df:d2:98:f6 WPA1PSKWPA2PSK
Tue Jan 10 22:44:52 2017 kern.info ap_client: Found network, trying to associate (essid: telenet-apn-D4F49, bssid: telenet-apn-D4F49, channel: 1, enc: WPA1PSKWPA2PSK, crypto: TKIPAES)
Tue Jan 10 22:44:55 2017 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:44:55 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:44:56 2017 daemon.warn odhcpd[935]: DHCPV6 CONFIRM IA_NA from 000100011f69939df0def1bc2580 on br-lan: not on-link fd1c:5a88:47dd::753/128
Tue Jan 10 22:44:56 2017 daemon.warn odhcpd[935]: DHCPV6 SOLICIT IA_NA from 000100011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:44:56 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresses
Tue Jan 10 22:44:56 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 0 addresses
Tue Jan 10 22:44:56 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 addresses
Tue Jan 10 22:44:56 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 addresses
Tue Jan 10 22:44:57 2017 daemon.warn odhcpd[935]: DHCPV6 REQUEST IA_NA from 000100011f69939df0def1bc2580 on br-lan: ok fd1c:5a88:47dd::753/128
Tue Jan 10 22:44:57 2017 daemon.info dnsmasq[1291]: read /etc/hosts - 1 addresses
Tue Jan 10 22:44:57 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/odhcpd - 1 addresses
Tue Jan 10 22:44:57 2017 daemon.info dnsmasq[1291]: read /tmp/hosts/dhcp - 1 addresses
Tue Jan 10 22:44:57 2017 daemon.info dnsmasq-dhcp[1291]: read /etc/ethers - 0 addresses
Tue Jan 10 22:45:00 2017 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:45:00 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
Tue Jan 10 22:45:03 2017 kern.info ap_client: apcli0 is associated
Tue Jan 10 22:45:08 2017 daemon.info dnsmasq-dhcp[1291]: DHCPREQUEST(br-lan) 192.168.1.146 10:0b:a9:37:ca:30
Tue Jan 10 22:45:08 2017 daemon.info dnsmasq-dhcp[1291]: DHCPACK(br-lan) 192.168.1.146 10:0b:a9:37:ca:30 MININT-VT9MA5R
kosmonaut pirx
Tue Jan 10, 2017 10:53 pm
Looks good, well done!
edit: Now
you've have to check for the correct psk/key. But i guess you already got that idea.
PreviousNext
Users browsing this forum: No registered users and 73 guests
