I am new to the VoCore and following the Tutorial, I have Connect to Power, set up serial application to 115200bps, 8 data bits, no even, 1 stop bit, set up AP + STA Mode. But when I came to the system flashing, it never goes through and stays at
System - Flashing...
The system is flashing now.
DO NOT POWER OFF THE DEVICE!
Wait a few minutes before you try to reconnect. It might be necessary to renew the address of your computer to reach the device again, depending on your settings.
Loading Waiting for changes to be applied...
The VoCore has its yellow and purple lights on and my computer is connected to it through wireless.
Can anybody help me?
Regards,
SOHO
Can't go through system flashing
- SOHO
Re: Can't go through system flashing
It is normal, you need to wait around 3~4 minutes, then reconnect the wifi, try 192.168.61.1(old firmware is 192.168.1.1)
- SOHO
Thanks for replying. I have been waiting for more than 3-4 hours but still didn't work. Is it normal?
- SOHO
Now something worse happened. It can be connected to the wifi but neither Putty nor 192.168.61.1 or 1.1 can connect to it. Putty won't show OpenWrt > line or any line, 192.168.61.1 says
Network Error
A communication error occurred: "No route to host"
Network Error
Users browsing this forum: Baidu [Spider] and 31 guests
