ssh close connection after insert password
- vbextreme
I access on vocore2 over luci without problems but if I try to connect over ssh the connection is closed afeter insert a password. Why?
Re: ssh close connection after insert password
weird issue, try mtk openwrt firmware, I guess it might be MT76 wifi driver issue.
link is here: http://vonger.cn/misc/vocore2/vocore2.mtk.bin
- vbextreme
The board does not start anymore, this is the second time I turn it on and I have not made any changes yet.
Is the firmware good for the lite version?
You will need a USB2TTL to recover the firmware, please check vocore.io/v2.html
- vbextreme
ok, successfull
For those who have similar problems.
download vocore2 lite
connect serial usb
install ckermit
execute kermit
thanks for support
[edit]
add set carrier-watch off
[/edit]
connect serial usb
install ckermit
execute kermit
> set line /dev/ttyUSB0
> set speed 115200
> set handshake none
> set flow-control none
> robust
> connect
Please choose the operation:
> 0
0: System Load Linux then write to Flash via Serial.
## Ready for binary (kermit) download to 0x80100000 at 115200 bps...
press key Ctrl+\ c
> send /home/<username>/Downloads/<firmware>.bin
> q
thanks for support
[edit]
[/edit]
- vbextreme
Once again broken.
While I was exploring the filesystem i started getting format execute error.
Try to close ssh and reconnect with same problem, connection close after insert password.
Power off and power on, now not view vocore2 wifi.
crestfallen
crestfallen
- vbextreme
I have found two issues
First::
usb 2-1 It continues to make mistakes
fix temporary
Second::
Same time can't connect over wifi
this is original rc.local
It does not seem to make much sense
edit in
save and reboot, now wifi work.
You should also delete those rows and create a specific script to perform the task
Here you can find a good starting point
for example (not tested)
/root/try-sta.sh
and in rc.local add
It would be useful to blink the LED during this phase
First::
fix temporary
# echo 'rmmod ohci_platform' >> /etc/rc.local
Second::
uci set wireless.sta.disabled=0
uci commit
/etc/init.d/network restart
sleep 10
uci set wireless.sta.disabled=1
uci commit
edit in
uci commit
rmmod ohci_platform
/root/try-sta.sh
uci commit
TIMEOUT=10
SLEEP=1
sta_err=0
while [ $(iwinfo | grep -c "ESSID: unknown") -ge 1 ]; do
let sta_err=$sta_err+1
if [ $((sta_err * SLEEP)) -ge $TIMEOUT ]; then
uci commit
break
fi
sleep $SLEEP
done
and in rc.local add
/root/try-sta.sh
- vbextreme
Vocore2-lite is completely broken.
I try to download source code and try to build with this tutorial, but return error
Download LEDE, build and upload firmware, but after few minutes get strange and randomly charater from serial. Network over ap is very very slow and I can't enable AP+STA
In this situation I don't understand if is broken hardware or software.
gdate.c: In function 'g_date_strftime':
gdate.c:2497:7: error: format not a string literal, format string not checked [-Werror=format-nonliteral]
tmplen = strftime (tmpbuf, tmpbufsize, locale_format, &tm);
Users browsing this forum: No registered users and 74 guests
