Hello all,
I have VoCore2 Lite, i tried to connect it to my home network through web interface and unfortunately i cant see it in the network now and cant see its IP. I am pretty sure that the device is working but i have no connection with it! My only connection with the device was through WiFi - web and SSH.
I have no second VoCore and cant reflash it this way
I have no access through USB2TTL either, as may be the cable that i am using is not good. The device manager shows that it is not recognized USB device, and no drivers can be installed. Something more, for me it is not clear which wire where to go. Right now i am using straight USB cable D+ go to RXD2 and D- go to TXD2 and that way the USB gets not recognition and cant install any drivers (i am doing it on Windows 10). I am using same cable for powering.
Is there any chance to reset the device to factory default settings just like some routers, with let say 10+ seconds of holding the reset or other procedure.
Regards!
VoCore2 Lite connection lost, factory reset might be needed
- limberjack
- limberjack
Re: VoCore2 Lite connection lost, factory reset might be nee
As i have answered that threat http://forum.vocore.io/viewtopic.php?f=16&t=3628&sid=d705d6f060c3fbf5aba63f42bc2137a4 i find one solution. I might use ethernet connection but it is important to know if the ports are active by default, can anyone answer that?
DON'T TRY TO CONNECT TO THE UART DIRECTLY WITH USB!!! The uart is old fashioned serial (think 1970's RS232 & 19200 baud modems) and it is only rated for 3v, USB operates at 5v. The vocore probably is ok but it isn't rated for 5v. For the uboot/Linux console you need something like
this
I don't know if the lites shipped with same uboot as the full units. What does the led do when it powers up? The uboot on the first units will flash the led for 3 seconds, then flash it very fast for another 3 seconds. If it does this there is an option to reload the system with either webpage over Ethernet or with a thumb drive over the USB host interface by triggering a gpio (reset button). If your led does this let me know and I'll post details on either.
Does the vocore open a wifi connection? You can see this on a wifi browser on your computer or mobile phone.
Do you have any other geeky hardware such as an Arduino?
this
- limberjack
Thanks for the reply,
i have somewhere USB-RS232TTL, but i was too lazy to search for it as i though it is already integrated, anywahy i hope it is not too late
The LED doesnt flash at all, it is steady lighted all the time. It did the same when i had connection. I am not sure if you get it but i lost any connection with it, that is why i try to find way to connect to it - LAN seems good idea if the ports are configured by default. I will search for my USB-RS232TTL
You need to re-read the first post, but anyway - yes i had connection until i tried to connect it to my home network as client, now i cant see it either as client in my network nor VoCore WiFi network.
I had some fun with Debian (no GUI at all) - i have some built applications and scripts on it, and i am not developer at all
I have played few years with Ethernut based on atmega128 - i have build couple of commercial devices based on that platform
I currently have Raspebry Pi2 with 7inch touch running raspbian but still i haven't built any custom applications.
I don't own arduino - but atmega128 was pretty much the same
I have somewhere MSPs, but they still waits for their better time
I started with VoCore as its dimensions get my attention, it is really suited for my personal projects right now.
noblepepper wrote:DON'T TRY TO CONNECT TO THE UART DIRECTLY WITH USB!!! The uart is old fashioned serial (think 1970's RS232 & 19200 baud modems) and it is only rated for 3v, USB operates at 5v. The vocore probably is ok but it isn't rated for 5v. For the uboot/Linux console you need something like
this
noblepepper wrote: What does the led do when it powers up? The uboot on the first units will flash the led for 3 seconds, then flash it very fast for another 3 seconds. If it does this there is an option to reload the system with either webpage over Ethernet or with a thumb drive over the USB host interface by triggering a gpio (reset button). If your led does this let me know and I'll post details on either.
noblepepper wrote:Does the vocore open a wifi connection? You can see this on a wifi browser on your computer or mobile phone.
noblepepper wrote:Do you have any other geeky hardware such as an Arduino?
Looks like you need to find the USB-RS232TTL it is probably the easiest path forward. Once you have it hooked up, this will put your vocore back like when you got it. The vocore variants with a piggyback board do have a converter built in but not the single board versions.
If firstboot doesn't want to work try
The led not blinking is probably that my changes to uboot that were on the original units is either disabled or removed on the lites, doesn't necessarily mean the unit is damaged. The mediatek chips are surprisingly resistant to abuse.
You need to either be more explicit in your posts or just answer questions when asked, I can think of two ways that you can get "connection with the device was through WiFi - web and SSH" only one involves the AP the vocore normally opens.
I asked about other hardware because you can often use as a USB-RS232TTL or to write the flash chip. The atmega128 and the rpi can both serve these purposes. The simple converter will be easier if you can find it.
Yes, the vocores are very small, the main reason I like them. They have their warts but just about any embedded system does.
mtd erase /tmp/rootfs_data
- limberjack
Hello all,
I got access in the end through USB-TTL i found in my junks.
Now, how can i reset the network settings.
I searched in
How can i change the network settings through command prompt?
strange because with that command i got the default settings but cant find it in my wireless list
I am struggling here
i am open for any suggestions
I searched in
/etc/network/interfaces
/etc/Wireless/mt7628/mt7628.dat
WirelessMode=2
root@OpenWrt:~# ifconfig
br-lan Link encap:Ethernet HWaddr B8:D8:12:67:4E:1E
inet addr:192.168.61.1 Bcast:192.168.61.255 Mask:255.255.255.0
inet6 addr: fd2c:3e29:9eb9::1/60 Scope:Global
inet6 addr: fe80::bad8:12ff:fe67:4e1e/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
TX packets:258 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:28030 (27.3 KiB)
Well the easy way is to do firstboot so you have a know working config to start from but if you want to go from where you are:
Openwrt keeps it's configurations in /etc/config/ all the changes made in the web interface (Luci) are kept there. Luci uses uci which is a command line tool (Google is your friend) which places files in /etc/config, you can edit these with vim, you want /etc/config/wireless and maybe /etc/config/network.
Make sure the line in the first section (radio?) in wireless has
If you don't want the vocore to open an access point put a
The settings for a client connection is in the third section (sta?). Since I use wpa security I have a
The main thing in network is you need to have a
After you change the files
I use
You may have firewall issues too.
All this is from my phone while drinking a beer so excuse typo's I'll post more exact info and examples in the morning.
uci show
uci show wireless
option disabled '0'
option disabled '1'
option encryption 'psk2'
option key 'mypasskey'
option ssid 'mynetworkname'
config interface wwan
option proto 'dhcp'
/etc/init.d/network restart
I use
ifconfig | grep 192
/etc/init.d/firewall stop
/etc/init.d/firewall start
Here is what /etc/config/wireless looks like on the latest "official" image for the lite out of the box:
I use vim to change the last 4 lines so it looks like this:
The end of logread's output looks like this at this point
Now I do a
It is fairly easy if you do it exactly right but it is easy to muck up a bit here or there so if you have issues check for typos, etc. When I have problems it is usually the ssid or passkey has a typo. You may have made changes somewhere else and
config wifi-device 'radio0'
option type 'ralink'
option variant 'mt7628'
option country 'CN'
option hwmode '11g'
option htmode 'HT40'
option channel 'auto'
option disabled '0'
config wifi-iface 'ap'
option device 'radio0'
option mode 'ap'
option network 'lan'
option ifname 'ra0'
option ssid 'VoCore2'
option encryption 'none'
config wifi-iface 'sta'
option mode 'sta'
option network 'wwan'
option ifname 'apcli0'
option ssid 'UplinkAp'
option key 'SecretKey'
option encryption 'psk'
option disabled '1'
option country 'CN'
option hwmode '11g'
option disabled '0'
option mode 'ap'
option ifname 'ra0'
option mode 'sta'
option ssid 'mywirelessnetworkname'
option key 'mywirelesspasskey'
option disabled '0'
Fri Feb 10 19:17:49 2017 kern.info ap_client: Found network - 11 elbono-home 10:6f:3f:e7:2b:a2 WPA2PSK
Fri Feb 10 19:17:49 2017 kern.info ap_client: No signal found to connect to
Fri Feb 10 19:17:59 2017 kern.info ap_client: apcli0 is not associated
Fri Feb 10 19:17:59 2017 kern.info ap_client: Scanning for networks...
Fri Feb 10 19:18:04 2017 kern.info ap_client: Found network - 11 elbono-home 10:6f:3f:e7:2b:a2 WPA2PSK
Fri Feb 10 19:18:04 2017 kern.info ap_client: No signal found to connect to
Fri Feb 10 19:18:14 2017 kern.info ap_client: apcli0 is not associated
Fri Feb 10 19:18:14 2017 kern.info ap_client: Scanning for networks...
Now I do a
Fri Feb 10 19:20:47 2017 daemon.notice netifd: wwan (2140): Sending discover...
Fri Feb 10 19:20:47 2017 daemon.notice netifd: wwan (2140): Sending select for 192.168.3.246...
Fri Feb 10 19:20:48 2017 daemon.notice netifd: wwan (2140): Lease of 192.168.3.246 obtained, lease time 43200
Fri Feb 10 19:20:48 2017 daemon.info avahi-daemon[1279]: Joining mDNS multicast group on interface apcli0.IPv4 with address 192.168.3.246.
Fri Feb 10 19:20:48 2017 daemon.info avahi-daemon[1279]: New relevant interface apcli0.IPv4 for mDNS.
Fri Feb 10 19:20:48 2017 daemon.info avahi-daemon[1279]: Registering new address record for 192.168.3.246 on apcli0.IPv4.
Fri Feb 10 19:20:48 2017 daemon.notice netifd: Interface 'wwan' is now up
Fri Feb 10 19:20:48 2017 daemon.info dnsmasq[1378]: reading /tmp/resolv.conf.auto
Fri Feb 10 19:20:48 2017 daemon.info dnsmasq[1378]: using local addresses only for domain lan
Fri Feb 10 19:20:48 2017 daemon.info dnsmasq[1378]: using nameserver 192.168.3.1#53
Fri Feb 10 19:20:49 2017 kern.info ap_client: Found network - 11 elbono-home 10:6f:3f:e7:2b:a2 WPA2PSK
Fri Feb 10 19:20:49 2017 kern.info ap_client: No signal found to connect to
Fri Feb 10 19:20:54 2017 kern.info ap_client: apcli0 is associated
Fri Feb 10 19:20:59 2017 kern.info ap_client: apcli0 is associated
ifconfig|grep 192
root@OpenWrt:/# ifconfig |grep 192
inet addr:192.168.3.246 Bcast:192.168.3.255 Mask:255.255.255.0
root@OpenWrt:/# ping -c5 google.com
PING google.com (172.217.4.14): 56 data bytes
64 bytes from 172.217.4.14: seq=0 ttl=54 time=20.039 ms
64 bytes from 172.217.4.14: seq=1 ttl=54 time=20.966 ms
64 bytes from 172.217.4.14: seq=2 ttl=54 time=19.358 ms
64 bytes from 172.217.4.14: seq=3 ttl=54 time=18.905 ms
64 bytes from 172.217.4.14: seq=4 ttl=54 time=20.548 ms
--- google.com ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 18.905/19.963/20.966 ms
root@OpenWrt:/# firstboot -y
/dev/mtdblock6 is mounted as /overlay, only erasing files
root@OpenWrt:/# reboot
root@OpenWrt:/# [ 1348.240000] br-lan: port 2(ra0) entered disabled state
[ 1348.250000] br-lan: port 1(eth0.1) entered disabled state
[ 1348.260000] device eth0.1 left promiscuous mode
[ 1348.270000] br-lan: port 1(eth0.1) entered disabled state
[ 1348.280000] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[ 1348.300000] device ra0 left promiscuous mode
[ 1348.300000] br-lan: port 2(ra0) entered disabled state
[ 1348.610000] device eth0 left promiscuous mode
[ 1352.650000] reboot: Restarting system
Software System Reset Occurred
*** Warning - bad CRC, using default environment
- limberjack
Hello "noblepepper",
unfortunatelly i have messed up
just few minutes after my last post i decide to read in open WRT forum about that,
i found exactly same info as you share, but when i changed the
it start to reboot itself and going through boot menu.
So i decided to reflash it, i downloaded the bin file, then downloaded kermit for windows - i am still windows guy
in Boot menu i am chosing either 0 or 4-th option (i dont remember exact text but it says that this is kermit mode).
Now the device waiting for the file.
i am exiting the PuTTY so i can release the serial and start Kermit
BTW couple things annoys me in kermit
firstly it works only with COM1 up to COM4 - i needed to change my COM, as it was 5 i made it COM1
the second is that the speed that kermit can use is up to 57600 baud rate, when i try to change the baud to 115200 and Apply the changes it desnt really change the option to 115200 but insted it writes 47856 or something like this (latter i can share exact digits) and i am not sure if this could be the problem for not sending/receiving the binary file
anyway i connect to VoCore with 57600, and when i try to send the file after couple of tries it sais there is no response from the receiver!
i am closing Kermit and start PuTTY again and check the VoCore, and it still stays in that mode and expect some file, but Kermit says "No response from the receiver"
Can you share more info about reflash the device with kermit mode, in the end i may finish with USB reflash, but i still want to try kermit mode.
Is there some specific TTY app that can be used with kermit protocol except Kermit and cKermit?
P.S. in reality i have connection with my device so i have answer to my original question - i used USB-3v3RS232TTL to have connection with VoCore, the wiring need to be crossed. If all is OK reflash is not needed just
P.S.2 Just realized that for powering i am using the USB-TTL board, is it possible that the power supply is not enough and thus make the device to reboot. Tonight i will try with stable and more powerful PSU
option mode 'ap'
Yes power may well be an issue if it reboots when it tries to power up the radio wifi uses. I had this problem on one particular unit that I blamed on my connections (jumper wires like you use on Arduino type stuff that didn't fit tightly in the headers I was using) I used multiple 5v connections that helped but didn't solve the problem. Moral of the story-you need good reliable power when the radio turns on.
If your reboot cycle starts when you see
I know nothing about kermit on windoze so no help here.
Does your uboot menu look like this?
If so it may have my modifications which allow changing baudrate. Try option 4 for uboot console, then
If uboot doesn't seem to recognize input at the new speed just switch back and it should work again, worst case power cycle and it will be at the original speed, until you saveenv uboot will boot up with the default (115200).
[ 26.750000] efuse_probe: efuse = 10000002
[ 26.980000] br-lan: port 1(eth0.1) entered forwarding state
[ 27.100000] tssi_0_target_pwr_g_band = 35
[ 27.100000] tssi_1_target_pwr_g_band = 35
[ 33.960000] <==== rt28xx_init, Status=0
[ 34.700000] device ra0 entered promiscuous mode
[ 34.710000] br-lan: port 2(ra0) entered forwarding state
Please choose the operation:
gpio trigger enabled
U-Boot 1.1.3 (Jun 25 2016 - 22:54:33)
VoCore2 > setenv baudrate 57600
## Switch baudrate to 57600 bps and press ENTER ...
*** baud: 57600 ***
VoCore2 > saveenv
Saving Environment to SPI Flash...
Erasing SPI Flash...
Writing to SPI Flash...
done
VoCore2 >
reset
Users browsing this forum: No registered users and 416 guests
