Reapportioning the filesystem at boot
KingBeetle
Wed Oct 18, 2017 6:00 am
After a fresh firmware flash and perhaps a little tinkering, my VoCore2 Lite filesystem looks something like this:
root@OpenWrt:~# df -h
Filesystem                Size      Used Available Use% Mounted on
rootfs                    1.1M    680.0K    472.0K  59% /
/dev/root                 5.5M      5.5M         0 100% /rom
tmpfs                    30.0M     88.0K     29.9M   0% /tmp
/dev/mtdblock6            1.1M    680.0K    472.0K  59% /overlay
overlayfs:/overlay        1.1M    680.0K    472.0K  59% /
tmpfs                   512.0K         0    512.0K   0% /dev
Is there any way I can configure the system to apportion say 5MB more to /overlay and 5MB less to /tmp, so it looks more like this?:
rootfs                    6.1M    680.0K      5.4M  10% /
tmpfs                    25.0M     88.0K     24.9M   0% /tmp
/dev/mtdblock6            6.1M    680.0K      5.4M  10% /overlay
overlayfs:/overlay        6.1M    680.0K      5.4M  10% /
Are the filesizes fixed or limited by hardware, or is there some flexibility? I REALLY could use that 5MB of space in /overlay for installing apps and giving the system a little "elbow room".
Re: Reapportioning the filesystem at boot
Thu Oct 19, 2017 2:30 pm
actually, tmpfs is your memory, not a real space, all data will lost after you reboot. tmpfs is map to /tmp.
KingBeetle
Thu Oct 19, 2017 5:39 pm
Ahh, OK. Well obviously THAT idea isn't going to work then.
Looks like I am going to have to set up some sort of external root using a flash drive like the link below describes.
https://samhobbs.co.uk/2013/11/more-space-for-packages-with-extroot-on-your-openwrt-router
KingBeetle
Wed Dec 27, 2017 6:47 am
I recently attached a female Type A USB connector to my VoCore2-Lite and was able to successfully move the root filesystem to a 16GB USB flash drive, using the link in the post above. My results:
First boot after fresh flash of VoCore2-Lite firmware and before modification:
rootfs                    1.1M    236.0K    916.0K  20% /
tmpfs                    30.0M    260.0K     29.8M   1% /tmp
/dev/mtdblock6            1.1M    236.0K    916.0K  20% /overlay
overlayfs:/overlay        1.1M    236.0K    916.0K  20% /
And after copying the VoCore2-Lite's root filesystem onto a 16GB USB flash drive and modifying /etc/fstab :
rootfs                   14.1G     57.9M     13.3G   0% /
/dev/sda1                14.1G     57.9M     13.3G   0% /
What a difference! Now I have 13GB of space on the filesystem for packages and files, instead of 916K.
Users browsing this forum: Bing [Bot], Google [Bot] and 239 guests
