Blue Light disappear
Lgonzalez4x4
Fri Dec 29, 2017 6:20 pm
Hi All
This is my first post and yesterday I received my Vocore2 Ultimate and I connected thougth microUSB for power and I could see the Vocore hotspot and even to open the OpenVtr after that I connected Rj45 cable and in this moment the blue light from vocore Disappear and I can't see the hotspot.. Do anyone give any support for this ??
I removed the RJ45 cable but I can't see the Wifi and blue ligth neither..
thanks in advance
Regards
Re: Blue Light disappear
Sat Dec 30, 2017 9:21 am
Maybe the internal top part and bottom part are disconnected.
Try to take inside out and pull the top bottom part together, then connect to power, check if it is working. Be careful when you do this, the static electric might broken its ddr2, better to wash hand before you do this.
Lgonzalez4x4
Tue Jan 16, 2018 11:21 pm
thanks , but it doesn't work. I bought another one..
Lgonzalez4x4
Wed Jan 17, 2018 12:09 pm
thank you for your response, no it doesn't work, I only see the light of RJ45 connector.
Is there any way to reset it ...
thanks
PD: I bought another one but I would like to use this too
Sat Jan 20, 2018 2:30 am
It is possible the top part is broken. When you use it, did the top part very hot?
Lgonzalez4x4
Fri Feb 02, 2018 6:24 pm
Yes a litle bit
Any suggestion ??
thanks in advance
Users browsing this forum: No registered users and 66 guests
