I have VoCore2 running in AP mode.
I kept getting IPv6 address from it, which I don't use. So I went ahead and deleted the WAN6 interface.
Now I can no longer access VoCore2. I see the SSID and can associate with it, but don't get DHCP address (IPv4).
I assigned myself a static address on the same subnet (192.168.61.X), but still can't ping or ssh into VoCore2.
I am getting really frustrated with this thing.
Can't connect after deleting WAN6 interface
- dimitry
- dimitry
Re: Can't connect after deleting WAN6 interface
I ended up reflashing the firmware and starting from scratch. What a waste of time.
This time I loaded new (not yet released) firmware. It doesn't have WAN6 interface.
Web GUI is really buggy. I ended up ditching it and doing everything via command line.
To disable DHCPv6 I edited the /etc/config/dhcp file and under "config dhcp 'lan'" section
removed "option dhcpv6" and "option ra". The unit no longer gives out IPv6 addresses.
Users browsing this forum: No registered users and 24 guests
