Snapcast is a independent multi room audio solution that is running on many devices.
See here: https://github.com/badaix/snapcast/
As it was a lot of work to get the client to compile on for the VoCore2 Ultimate I decides to share the binaries that run on the stock VoCore2 OpenWRT image 2017.05.27.
Due to upload limitations I have to split the zip file into 3 parts and this post has
sanpclient-VoCore2Ultimate-OpenWRT15.05.zip
attached
sanpclient-VoCore2Ultimate-OpenWRT15.05.z01
sanpclient-VoCore2Ultimate-OpenWRT15.05.z02
will be uploaded in the next posts.
The following ipk packages are included:
alsa-lib_1.0.28-1_ramips_24kec.ipk
avahi-dbus-daemon_0.6.31-12_ramips_24kec.ipk
libavahi-client_0.6.31-12_ramips_24kec.ipk
libavahi-dbus-support_0.6.31-12_ramips_24kec.ipk
libflac_1.3.1-1_ramips_24kec.ipk
libid3tag_0.15.1b-4_ramips_24kec.ipk
libogg_1.3.2-2_ramips_24kec.ipk
libvorbisidec_1.0.3-20150104-1_ramips_24kec.ipk
snapclient_0.15.0_ramips_24kec.ipk
All packages need to be copied to the VoCore2 and have to be installed to satisfy the dependencies. Some more dependencies are pulled automatically from the package repository.
Once install configure your sanpsever in /etc/default/sanpclient. The client will start at boot up and will stream the snapserver stream automatically if available.
Please read the snapcast git README.md to setup a server.
Enjoy.
VoCore2 Unltimate running Snapclient
- cyberhippy
- sanpclient-VoCore2Ultimate-OpenWRT15.05.zip
- snapclient for VoCore2 part 1/3
- (223.98 KiB) Downloaded 3352 times
- cyberhippy
Re: VoCore2 Unltimate running Snapclient
sanpclient-VoCore2Ultimate-OpenWRT15.05.z01 please remove the .zip from the attached file
attached
will be uploaded in the next post.
Enjoy.
attached
Enjoy.
- sanpclient-VoCore2Ultimate-OpenWRT15.05.z01.zip
- snapclient for VoCore2 part 2/3
- (256 KiB) Downloaded 3419 times
- cyberhippy
sanpclient-VoCore2Ultimate-OpenWRT15.05.z02 please remove the .zip from the attached file
Enjoy.
Enjoy.
- sanpclient-VoCore2Ultimate-OpenWRT15.05.z02.zip
- snapclient for VoCore2 part 3/3
- (256 KiB) Downloaded 3364 times
Users browsing this forum: Google [Bot] and 119 guests
