Hi
I have some issues with the VoCore 2 Lite
1) I can't seem to get the SD card slot to work. I've enabled the kmod-sdhci and kmod-sdhci-mt7620 options under Kernel Modules -> Other modules, but I don't see any mmc devices when I run ls /dev.
2) When building the firmware for VoCore 2 Lite, I don't see i2c-0 when I run ls /dev, but I do when I build the firmware for VoCore 2 and install it on the lite
3) When reading data from the I2C bus with ioctl, I'm only getting around 6% of the speed I'm expecting to get (I should be able to read about 12000 1 byte registers per second if the bus is running at 400khz, but in practice I only get about 750). I've read I may need to make a device driver if I want to get full speed on Linux, but haven't been able to find any information on how to set up a development environment for drivers.
The options I've set in make menuconfig:
Target System: MediaTek Ralink MIPS
Subtarget: MT76x8 based boards
Target Profile: VoCore Vocore2-Lite
Base System -> wireless-tools
Kernel Modules -> I2C Support -> kmod-i2c-core, kmod-i2c-mt7628
Kernel Modules -> Other Modules -> kmod-sdhci, kmod-sdhci-mt7620
LuCI -> Collections -> luci
Issues with VoCore 2 Lite
- tlopes
Re: Issues with VoCore 2 Lite
Hi, please use our i2c patch for the i2c driver, download at github.com/vonger/vocore2
Also SD card need to patch, because default driver has bug can not allow cd polling mode, please download the patch from the same address.
DTS also need to modify, you can reference to VOCORE2.dts
- tlopes
Both patches were applied. I'm not 100% sure what exactly needs to be modified in the DTS file (or which one, for that matter):
so I updated both to this:
On the actual device, if I watch the terminal output in teraterm, I see boot messages suggesting it's loading drivers for I2C and SDHCI, and when I run lsmod I get:
It looks like the I2C and SD card kernel modules are loaded, but when I run ls /dev, I don't see i2c-0 or any mmc related devices:
$ find . -name vocore2.dts
./build_dir/toolchain-mipsel_24kc_gcc-7.5.0_musl/linux-4.14.180/arch/mips/boot/dts/ralink/vocore2.dts
./build_dir/target-mipsel_24kc_musl/linux-ramips_mt76x8/linux-4.14.180/arch/mips/boot/dts/ralink/vocore2.dts
/dts-v1/;
#include "mt7628a.dtsi"
compatible = "vocore,vocore2", "ralink,mt7628a-soc";
model = "VoCore2";
memory@0 {
device_type = "memory";
reg = <0x0 0x8000000>;
chosen {
bootargs = "console=ttyS2,115200";
stdout-path = &uart2;
sdhci {
status = "okay";
mediatek,cd-poll;
# lsmod
crc_ccitt 1035 1 ppp_async
ehci_hcd 34871 1 ehci_platform
ehci_platform 4656 0
gpio_button_hotplug 6896 0
i2c_core 22728 2 i2c_mt7621,i2c_dev
i2c_dev 4640 0
i2c_mt7621 2480 0
ip_tables 10061 4 iptable_nat,iptable_mangle,iptable_filter
ip6_tables 9825 24 ip6table_mangle,ip6table_filter
ip6t_REJECT 1072 2
ip6table_filter 688 1
ip6table_mangle 1232 0
ipt_MASQUERADE 720 1
ipt_REJECT 1008 2
iptable_filter 688 1
iptable_mangle 944 0
iptable_nat 752 1
leds_gpio 2928 0
ledtrig_usbport 2784 0
mmc_block 23590 0
mmc_core 87445 3 mmc_block,sdhci,mtk_sd
mt7628 953872 1
mtk_sd 20192 0
nf_conntrack 57893 12 nf_conntrack_ipv6,ipt_MASQUERADE,xt_state,xt_nat,xt_conntrack,xt_REDIRECT,nf_nat_masquerade_ipv4,nf_conntrack_ipv4,nf_nat_ipv4,nf_nat,nf_flow_table,nf_conntrack_rtcache
nf_conntrack_ipv4 4368 10
nf_conntrack_ipv6 4576 4
nf_conntrack_rtcache 2672 0
nf_defrag_ipv4 1046 1 nf_conntrack_ipv4
nf_defrag_ipv6 4798 1 nf_conntrack_ipv6
nf_flow_table 13759 2 xt_FLOWOFFLOAD,nf_flow_table_hw
nf_flow_table_hw 2160 1
nf_log_common 2703 2 nf_log_ipv4,nf_log_ipv6
nf_log_ipv4 3472 0
nf_log_ipv6 4176 0
nf_nat 9451 4 xt_nat,nf_nat_redirect,nf_nat_masquerade_ipv4,nf_nat_ipv4
nf_nat_ipv4 3441 1 iptable_nat
nf_nat_masquerade_ipv4 1756 1 ipt_MASQUERADE
nf_nat_redirect 1531 1 xt_REDIRECT
nf_reject_ipv4 2147 1 ipt_REJECT
nf_reject_ipv6 2536 1 ip6t_REJECT
nls_base 5152 1 usbcore
ohci_hcd 22818 1 ohci_platform
ohci_platform 4176 0
ppp_async 6928 0
ppp_generic 22786 3 pppoe,ppp_async,pppox
pppoe 9232 0
pppox 1386 1 pppoe
sdhci 29717 1 sdhci_pltfm
sdhci_pltfm 2578 0
slhc 5307 1 ppp_generic
usb_common 2551 1 usbcore
usbcore 132419 5 ledtrig_usbport,ohci_platform,ohci_hcd,ehci_platform,ehci_hcd
x_tables 13999 23 ipt_REJECT,ipt_MASQUERADE,xt_time,xt_tcpudp,xt_state,xt_nat,xt_multiport,xt_mark,xt_mac,xt_limit,xt_conntrack,xt_comment,xt_TCPMSS,xt_REDIRECT,xt_LOG,xt_FLOWOFFLOAD,iptable_mangle,iptable_filter,ip_tables,ip6table_mangle,ip6table_filter,ip6_tables,ip6t_REJECT
xt_FLOWOFFLOAD 3072 0
xt_LOG 816 0
xt_REDIRECT 752 0
xt_TCPMSS 2832 0
xt_comment 528107
xt_conntrack 2352 12
xt_limit 1232 20
xt_mac 656 0
xt_mark 720 0
xt_multiport 1328 0
xt_nat 1584 0
xt_state 752 0
xt_tcpudp 1840 8
xt_time 1808 0
# ls /dev
bus mtd3 network_throughput
console mtd3ro null
cpu_dma_latency mtd4 port
full mtd4ro ppp
gpiochip0 mtd5 ptmx
gpiochip1 mtd5ro pts
gpiochip2 mtd6 random
kmsg mtd6ro shm
log mtdblock0 tty
memory_bandwidth mtdblock1 ttyS0
mtd0 mtdblock2 ttyS1
mtd0ro mtdblock3 ttyS2
mtd1 mtdblock4 urandom
mtd1ro mtdblock5 watchdog
mtd2 mtdblock6 watchdog0
mtd2ro network_latency zero
From the lsmod, the driver is loaded, please call "dmesg" on console, and paste the boot up log here. Maybe something wrong at loading the driver
- tlopes
Here's the output for dmesg:
# dmesg
[ 0.000000] Linux version 4.14.180 (user@user-Virtual-Machine) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11063-85e04e9f46)) #0 Sat May 16 18:32:20 2020
[ 0.000000] Board has DDR2
[ 0.000000] SoC Type: MediaTek MT7688 ver:1 eco:2
[ 0.000000] MIPS: machine is VoCore2-Lite
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat 8049f360, node_mem_map 81000040
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] random: get_random_bytes called from start_kernel+0x90/0x478 with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS2,115200 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Writing ErrCtl register=00067fb5
[ 0.000000] Readback ErrCtl register=00067fb5
[ 0.000000] Memory: 58700K/65536K available (3704K kernel code, 168K rwdata, 864K rodata, 1208K init, 200K bss, 6836K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 256
[ 0.000000] intc: using register map from devicetree
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] timer_probe: no matching timers found
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
[ 0.000012] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[ 0.007541] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[ 0.073503] pid_max: default: 32768 minimum: 301
[ 0.078186] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.084541] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.096935] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.106438] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.112373] pinctrl core: initialized pinctrl subsystem
[ 0.118435] NET: Registered protocol family 16
[ 0.149629] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.155222] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.160838] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.170801] clocksource: Switched to clocksource MIPS
[ 0.176780] NET: Registered protocol family 2
[ 0.181858] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.188553] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.194743] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.201009] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.206611] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.212947] NET: Registered protocol family 1
[ 0.217122] PCI: CLS 0 bytes, default 32
[ 0.220508] Crashlog allocated RAM at address 0x3f00000
[ 0.227203] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.239242] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.244874] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.264630] io scheduler noop registered
[ 0.268360] io scheduler deadline registered (default)
[ 0.274233] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.281634] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.290986] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.300013] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.308549] console [ttyS2] enabled
[ 0.315561] bootconsole [early0] disabled
[ 0.324995] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.337764] m25p80 spi0.0: gd25q64 (8192 Kbytes)
[ 0.342567] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.349008] Creating 4 MTD partitions on "spi0.0":
[ 0.353903] 0x000000000000-0x000000030000 : "u-boot"
[ 0.359869] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.366172] 0x000000040000-0x000000050000 : "factory"
[ 0.372232] 0x000000050000-0x000000800000 : "firmware"
[ 0.381404] 2 uimage-fw partitions found on MTD device firmware
[ 0.387419] Creating 2 MTD partitions on "firmware":
[ 0.392512] 0x000000000000-0x000000184e37 : "kernel"
[ 0.398484] 0x000000184e37-0x0000007b0000 : "rootfs"
[ 0.404396] mtd: device 5 (rootfs) set to be root filesystem
[ 0.411710] 1 squashfs-split partitions found on MTD device rootfs
[ 0.418002] 0x0000003c0000-0x0000007b0000 : "rootfs_data"
[ 0.425177] libphy: Fixed MDIO Bus: probed
[ 0.439338] rt3050-esw 10110000.esw: link changed 0x00
[ 0.447964] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[ 0.458141] NET: Registered protocol family 10
[ 0.466624] Segment Routing with IPv6
[ 0.470459] NET: Registered protocol family 17
[ 0.475097] 8021q: 802.1Q VLAN Support v1.8
[ 0.489754] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.503577] Freeing unused kernel memory: 1208K
[ 0.508172] This architecture does not have kernel memory protection.
[ 1.565050] init: Console is alive
[ 1.568756] init: - watchdog -
[ 2.190820] random: fast init done
[ 2.946624] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 3.040443] usbcore: registered new interface driver usbfs
[ 3.046188] usbcore: registered new interface driver hub
[ 3.051747] usbcore: registered new device driver usb
[ 3.062803] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.071254] ehci-platform: EHCI generic platform driver
[ 3.086907] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 3.093734] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 3.099050] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 3.104938] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 3.113114] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 3.140827] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 3.148147] hub 1-0:1.0: USB hub found
[ 3.152456] hub 1-0:1.0: 1 port detected
[ 3.159680] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.167710] ohci-platform: OHCI generic platform driver
[ 3.173381] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 3.180338] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 3.188498] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 3.265942] hub 2-0:1.0: USB hub found
[ 3.270132] hub 2-0:1.0: 1 port detected
[ 3.287321] mtk-sd: MediaTek MT6575 MSDC Driver
[ 3.294948] sdhci: Secure Digital Host Controller Interface driver
[ 3.301295] sdhci: Copyright(c) Pierre Ossman
[ 3.306973] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.316238] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 3.326475] init: - preinit -
[ 4.384621] rt3050-esw 10110000.esw: link changed 0x00
[ 4.437736] random: procd: uninitialized urandom read (4 bytes read)
[ 7.805027] jffs2: notice: (385) jffs2_build_xattr_subsystem: complete building xattr subsystem, 6 of xdatum (0 unchecked, 3 orphan) and 6 of xref (3 dead, 0 orphan) found.
[ 7.822770] mount_root: switching to jffs2 overlay
[ 7.854991] overlayfs: upper fs does not support tmpfile.
[ 7.867393] urandom-seed: Seeding with /etc/urandom.seed
[ 8.046519] procd: - early -
[ 8.049568] procd: - watchdog -
[ 8.767286] procd: - watchdog -
[ 8.770884] procd: - ubus -
[ 8.919487] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.004055] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.011166] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.018652] procd: - init -
[ 9.679817] kmodloader: loading kernel modules from /etc/modules.d/*
[ 9.716313] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 9.752003] i2c /dev entries driver
[ 10.209190] <-- RTMPAllocTxRxRingMemory, Status=0, ErrorValue=0x
[ 10.216550] <-- RTMPAllocAdapterBlock, Status=0
[ 10.252763] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.271328] urngd: v1.0.2 started.
[ 10.290641] nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
[ 10.491897] xt_time: kernel timezone is -0000
[ 10.518159] PPP generic driver version 2.4.2
[ 10.532221] NET: Registered protocol family 24
[ 10.553019] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 10.766050] random: crng init done
[ 10.769520] random: 6 urandom warning(s) missed due to ratelimiting
[ 20.185467] br-lan: port 1(eth0.1) entered blocking state
[ 20.191194] br-lan: port 1(eth0.1) entered disabled state
[ 20.197041] device eth0.1 entered promiscuous mode
[ 20.201962] device eth0 entered promiscuous mode
[ 20.242500] br-lan: port 1(eth0.1) entered blocking state
[ 20.247992] br-lan: port 1(eth0.1) entered forwarding state
[ 20.253922] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 20.948621] efuse_probe: efuse = 10000012
[ 21.122001] tssi_1_target_pwr_g_band = 35
[ 26.726222] <==== rt28xx_init, Status=0
[ 26.730263] ttyS ttyS0: 1 input overrun(s)
[ 26.751388] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 27.655212] br-lan: port 2(ra0) entered blocking state
[ 27.660507] br-lan: port 2(ra0) entered disabled state
[ 27.666154] device ra0 entered promiscuous mode
[ 27.670939] br-lan: port 2(ra0) entered blocking state
[ 27.676191] br-lan: port 2(ra0) entered forwarding state
From dmesg, i2c created interface under /dev/, you should able to find it. weird.
You can try the firmware at vocore.io/v2.html, check if there is any device.
Users browsing this forum: No registered users and 55 guests
