I2C: I don't even know how to start!
BryanBarbosa
Thu Mar 17, 2022 11:25 pm
Hello Vocorers!
I've been trying to use the I2C on Vocore 2 to get data from an accelerometer, two IR sensors, one light sensor, one temperature sensor and one Ads1115 module to get readings from analog pins. BUT I DON'T EVEN KNOW HOW TO START!!! :(
Could someone please help me by giving the direction?
I already installed i2c-tools on Vocore 2, but I can not understand how does it work.
Could someone indicate the way?
Re: I2C: I don't even know how to start!
Mon Mar 21, 2022 4:20 am
1. connect i2c device CLK, DAT to VoCore2 I2C port
2. power on that devices.
3. use i2cdetect -y 0, check if there is any device on i2cbus can be detected.
From this step you can find the device and its address. rest need to code because different i2c device has different read/write way, maybe not compatible i2cdump and i2cwrite or i2cread.
Users browsing this forum: Baidu [Spider] and 36 guests
