VoCore2 with sd card slot: SD card not detected
wannabee
Tue Jun 14, 2022 8:58 am
i have a VoCore2 + USB & MicroSD Slot. I have updated the firmware to openwrt 19.07.3 ( http://vonger.cn/misc/vocore2/20200811.19073.bin ). It boots ok and i can connect to it through web and ssh.
If i insert a card (16GB, sandisk) it is not detected. I don't see any new entry in dmesg if i insert/remove a card, it doesn't gets auto-mounted, df doesn1t show it.
What am i doing wrong?
Thank You!
Re: VoCore2 with sd card slot: SD card not detected
Mon Jun 20, 2022 1:19 am
First check if hardware connection is all OK, then check if the SD card is normal. If still not work, try 20191127.bin firmware(http://vonger.cn/misc/vocore2/20191127.bin), that is original firmware.
wannabee
Tue Jun 21, 2022 9:33 am
I just built an openwrt 21.02.3 image with your SD-card patch: https://github.com/Vonger/vocore2/blob/ ... port.patch
It seems to be working correctly.
I use it basically for this (old photo):
Wed Jun 22, 2022 3:04 am
haha, looks amazing :)
Users browsing this forum: No registered users and 22 guests
