Ahoj,
I have purchased a VoCore2 Ultimate in October 2022 and now I made it working.
When pluggin in a LAN cable, I noticed that it went in really hard. I could only remove it with force with pliers, which destroyed the cable.
The reasin is that the opening in the case is too narrow.
So this is a bug report regarding the case, with the request to design the opening for the LAN cable a bit wider.
I helped myself by milling away a bit of plastic to make it wider.
Regards!
[Bug] VoCore2 case: LAN cable opening too narrow, destroys
dreieck - Posts: 7
VoCore 2 Ultimate.
Re: [Bug] VoCore2 case: LAN cable opening too narrow, destro
Yes, new case has the problem, we has fixed that before shipping...need to cut wider the three sides of the LAN case. The mold is too old need to replace.
dreieck - Posts: 7
Vonger wrote:we has fixed that before shipping...
Actually, you had _not_ fixed that before shipping, otherwise I would not have got that problem.
VoCore 2 Ultimate.
Users browsing this forum: Bing [Bot] and 49 guests
