The sim-racing dashboard demonstrator is using a CH32V003 to control WS2182B LED's is an excellent example. However, I have had trouble sourcing a mounted CH32V003 like the one in demonstrator.
I have successfully downloaded and compiled the Vonger/V7B_WS2812B code ready to upload the CH32V003 and have done so to a dev-board. However, the dev-board is not ideal for embedding with the MPRO.
So, I have two questions:
1: Was the CHV32003 board a custom PCB or did you find it available in bulk?
2: Does the Screen+MPRO board require a firmware update to drive the CH32V003 or does it come ready to control it over I2C using the SimHub plugin?
Many thanks.
A
Screen + MPRO + CH32V003
- BertramRaven
Re: Screen + MPRO + CH32V003
About your two question:
1. CH32V003 is a customize PCH solution, if you do not want to DIY it, you can ask sales@vocore.io to get already made one.
2. Yes, CH32V003 need to load firmware or it can not work. Also we can load it for you for your easier usage.
Users browsing this forum: No registered users and 9 guests
