I've successfully gotten PHY0 to work with an ethernet transformer. Now I'd like to use one more ethernet PHY. Namely, the PHY #4.
Therefore I soldered another ethernet transformer and ethernet jack to these pins:
- * SD CLK (54)
* SD CMD (55)
* SD D3 (56)
* SD D2 (57)
Unfortunately this was not enough to get it working. Then I found your blog post: https://vonger.cn/?p=15041 and this post on the Forum: viewtopic.php?f=16&t=4071
... so I used busybox's "devmem" to alter the registers:
First read register so what the current state is
root@openwrt:/# devmem 0x1000003c
0x00FE01FF
Then alter according to blog post:
devmem 0x1000003c w 0xe001ff
At this point, the "10M" LED on the attached Netgear switch lights up, but at the same time, the VoCore seems to freeze: The UART terminal on TXD2 and RXD2 renders unresponsive.
Reading your instructions more carefully, I found out that UART 2 cannot be used anymore. (Why is that? How could I find out myself?
Therefore I moved my serial console to UART 1 (RXD1/TXD1) by using this patch for the Linux device tree:
--- a/target/linux/ramips/dts/mt7628an_vocore_vocore2.dtsi
+++ b/target/linux/ramips/dts/mt7628an_vocore_vocore2.dtsi
@@ -10,7 +10,7 @@
chosen {
- bootargs = "console=ttyS2,115200";
+ bootargs = "console=ttyS1,115200";
It worked fine and the _Linux_ serial console is now available at the desired ports RXD1/TXD1.
RXD2/TXD2 should now be unoccupied and will not disturb ethernet operation anymore.
Now I wanted to apply a similar patch for UBoot, because the UBoot serial also needs to change from UART2 to UART1. I've tried the following in the Uboot Vocore Device tree:
--- a/arch/mips/dts/vocore_vocore2.dts
+++ b/arch/mips/dts/vocore_vocore2.dts
@@ -13,7 +13,7 @@
model = "VoCore2";
aliases {
- serial0 = &uart2;
+ serial0 = &uart1;
spi0 = &spi0;
@@ -32,8 +32,8 @@
chosen {
- stdout-path = &uart2;
+ stdout-path = &uart1;
@@ -46,11 +46,11 @@
-&uart2 {
+&uart1 {
status = "okay";
pinctrl-names = "default";
- pinctrl-0 = <&uart2_pwm_pins>;
+ pinctrl-0 = <&uart1_pwm_pins>;
&spi0 {
... but unfortunately the U-Boot console is still not available at UART1. Am I missing something? I'd like to resolve this issue first and then continue with the Ethernet PHY #4 port
