I wanted to test ethernet on my vocore without the dock.
I cut a ethernet cable and connected it to the vocore.
This is how i connected it.
wire 1 (White/orange) -- p4TP
wire 2 (Orange) -- p4TN
Wire3 (white/green) -- p4RP
wire6 (green) -- P4RN
Is that no enough or do i need to enable it somewhere else?
Ethernet connection with straightthrough
- Diabolus
- Pyrofer
Re: Ethernet connection with straightthrough
You need Ethernet magnetics and a 1.8v pin on the centertap.
Look on RS/Digikey/Mouser/Farnell etc for an RJ45 with integrated magnetics. There will be 3 pins for Rx and TX. Each centertap pin goes to 1.8v then it all works. Without that you get nowhere.
- Peter
What kind of minimum circuitry would I need for a PCB to PCB ethernet cable? (ca. 5cm in length)
I tried to wire it directly but no link is detected.
- Peter H
Do you definitely need Ethernet? It would be very easy to make a serial connection at that distance.
- Pyrofer
As I said, if you want Ethernet then you need the magnetics with 1.8v on the center tap.
You can buy "magjack" RJ45 ports with the magnetics built in which is what I have used on all of my VoCore boards.
- Peter
Did anybody successfully connected to ethernet without magneticks/rj45 jack yet?
(which should be possible - see TI application note www.ti.com/lit/an/snla088a/snla088a.pdf )
- Greenwire-Elektronik
Peter - this app note is only applicable for TI products - you really should think about using magnetics - at least for ground compensation current which could damage your circuit.
- Ruphobia
I've wondered about doing this for years with various little Ethernet boards; This would be great for daisy chaining or cluster computing back plane, small robots, etc. Did you ever make this work?
- SteeevO
I've also been having this same problem.
I didn't realize that more components were required.
Users browsing this forum: No registered users and 155 guests
