A VoCore Repository
Re: A VoCore Repository
Wed Feb 04, 2015 4:56 pm
Please don't switch subjects in a thread, it ruins the ability to find answers about a particular subject.
This thread is about using the repository I set up for people that don't want to compile their openwrt image themselves. If your speed problem is related to the image I compiled, please post a comparison between it and the stock image at http://vonger.cn/upload/vocore.v1.0.bin
Your question looks to me like it belongs in the Help section of the forum where interested people can help with your problem.
Fri May 29, 2015 5:26 pm
I'm surprised no one else has noticed/posted this but chaos calmer now has the first release candidate available. We finally have a (semi) stable point of reference.
The official repository is here. I have also incorporated most of the changes specific to the VoCore in my github repository which you can find here. There is a prebuilt repository of my stuff here
The main changes I have done can be seen here, they mainly are the same changes between the stock VoCore and and the official openwrt but my prebuilt image also points opkg.conf at the repository above.
There are a lot of bugs fixed since the VoCore came out so I definitely recommend giving this a whirl!
charliex
Sat May 30, 2015 4:19 am
i've been using it for a while now, works great , have updated 30+ vocores so far.
Sat May 30, 2015 11:23 am
The main thing I like about a stable reference is you can flash an image and afterwards you can install ipkg's without worry about incompatibilities because of software versions.
I noticed while building my repo that the VOCORE.dts in the official repo is for the alpha version (I think). This sets the firmware partition to 8 meg instead of the 16 meg that the 1.0 version has.
Here is a demonstration:
Official repo:
root@OpenWrt:/# df -h
Filesystem                Size      Used Available Use% Mounted on
rootfs                    4.4M    304.0K      4.1M   7% /
/dev/root                 2.3M      2.3M         0 100% /rom
tmpfs                    14.2M     68.0K     14.1M   0% /tmp
/dev/mtdblock6            4.4M    304.0K      4.1M   7% /overlay
overlayfs:/overlay        4.4M    304.0K      4.1M   7% /
tmpfs
My repo:
rootfs                   12.3M    500.0K     11.8M   4% /
/dev/root                 2.5M      2.5M         0 100% /rom
/dev/mtdblock6           12.3M    500.0K     11.8M   4% /overlay
overlayfs:/overlay       12.3M    500.0K     11.8M   4% /
tmpfs                   512.0K         0    512.0K   0% /dev
I also set the uboot-env partition to read/write so my u-boot envtools port can set u-boot environment variables from Linux
TomasCook
Wed Sep 23, 2015 11:12 pm
Just got my VoCore, I'll try to clone your repo and see if it works out of the box.
Did you try to build aircrack-ng and can-utils (cangen/candump ...) ?
Thanks !
Previous
Users browsing this forum: No registered users and 423 guests
